How to dertermine wich joystick can fit on my quickie 646se
Postby yeshelp » 06 Jan 2025, 00:53
Hello everybody,
I have a quickie 646 se and I would like to know which joystick could i buy compatible to fit on the chair.
The two previous joystick models i had , had no female connector on joystick and both time it is the cable that have broken. So it sucks because the joystick itself works. I drop the joystick often since i use it on my lap switching hands.
Maybe there are joysticks that have a female connector so that next time the cable breaks i could just but a new cable (much cheaper than buying the joystickfusioned with the cable).
in pict is the identity of the chair because i think we need to be carefull with the computer at the back compatibility.
at the moment what comes out of the computer from the back is a redel connector. I am open to not expensive chinese joysticks (some are less than 100) but the connector they use is different from a redel.
Is there some kind of adapter that can allow the redel to connect to other joystick connector?
Im open to suggestions .
yeshelp
Re: How to dertermine wich joystick can fit on my quickie 64
Postby Burgerman » 06 Jan 2025, 02:15
The non branded version, was called the Pilot Plus.
Those come with no lights or seating options and just speed settings.
Or with lights etc, all will work just the same.
https://www.ebay.co.uk/itm/235732945854
Overpriced by around 5 times but new.
https://www.ebay.co.uk/sch/i.html?_from ... &_osacat=0
They are all now old. And overpriced used unreliable junk. If you find one as new then it will be 4x the cost of a R-NET one...
I can find R-NET led joysticks unused, for £45 and 90A power modules for 40 to £50.
Postby ex-Gooserider » 07 Jan 2025, 03:57
Used ones do still work... The Pilot+ branded joysticks usually had plugs in the body rather than the cables like the Qtronix rebrands... the big problem is that it can be hard to find the cables... ANY Pilot+ brand stick will work on those chairs, the only other issue is the mounting hardware is different, so you will need to make / purchase something new.
Postby yeshelp » 07 Jan 2025, 20:26
Burgerman wrote:The non branded version, was called the Pilot Plus.
For my comprehension, r-net are like less old than what i have so there are more online to buy because still in production so more availaible correct?
they are still 600us new, 300 us 200 used. I do like that the wire is replacable .
For knowledge, if going that route , i need to change the power module wich is the computer at the back of the chair correct?
Does it fit in my chair? would the motors and all the other stuff be able to plug in . Compatibility issues. ( in dont need incline or leg lift)
yeshelp
Postby yeshelp » 07 Jan 2025, 20:33
ex-Gooserider wrote:Used ones do still work... The Pilot+ branded joysticks usually had plugs in the body rather than the cables like the Qtronix rebrands... the big problem is that it can be hard to find the cables... ANY Pilot+ brand stick will work on those chairs, the only other issue is the mounting hardware is different, so you will need to make / purchase something new.
thanks for adding these info. Do you know why the cables are hard to find? do they still produce them?
Do you know their name? pilot plus cable?
yeshelp
Postby Burgerman » 07 Jan 2025, 21:29
MANY different and fully interchangable R-Net systems and parts as well as 4 different power modules (the thing you are calling a computer) are all currently still made. And fitted to at least 20 different brands of chairs across the world. They are cheaper, and common. Easy to find used.
Look at the picture below.
130 total $ DOLLARS. NEW/or UNUSED. Ebay.
As far as I know, yes it should all just plug in.
But it WILL need a little knowledge and programming...
THIS is all you need!
If only interested in go. No seating options.
I paid £45 ($55 dollars US) for the Power Module. Thats 120A capable, much better than you have now!
I paid £150 ($190 US) for the CJSM2 brand new joystick.
I paid £15 ($20) for that bus cable.
In fact I bought a LOT of brand new R-Net stuff cheaply!
I bought a low end LED joystick for £45 too. So the COMPLETE system would have cost you £105 or $130 US. But you
MUST BUY RIGHT! Most I see are way overpriced.
And you WILL NEED a R-Net programmer. But you should have one for any chair regardless if you ever hope to be in control.
Postby Burgerman » 07 Jan 2025, 22:55
Here is an EXAMPLE of what I just bought on Ebay JUST NOW. While looking because of you... This is more than you need.
I fish ebay for months at a time and only buy pristine or new stuff. CHEAPLY. If the price is too high, wait. I now have 6 sets of R-net complete systems. But when its cheap its good to have spares.
1. £50 (65 US dollars)
For an unmarked 120A R-Net power module. Now I have 4...
A ISM6-L 6 channel seating and lighting module. Now I have 4 of these too!
A bus cable thats worth the £50 alone... I have a box of these.
https://www.ebay.co.uk/itm/276733019965
2. A basic LED R-net Joystick BRAND NEW! £50
Brand new i=unused R-net joystick. I have 5 now...
https://www.ebay.co.uk/itm/296929357144
For ONE HUNDRED TOTAL COST, a complete system inc all seating and lighting! All brand new or as good as new. All 4 items, I bought TEN MINUTES AGO!!! Both sellers 100% feedback. Full rehab chair capable system.
Thats everything needed for power drive, powered seating lift, recline, tilt, power footrest angle and length, And lights and one channel left over!
Note, it says I BOUGHT THIS power module, bus cable, and seating and lighting module (all 3) literally 10 mins ago...
Note, it says I BOUGHT THIS JOYSTICK (literally 10 mins ago)
Postby Burgerman » 07 Jan 2025, 23:13
ExGoosrider - this is why!
No point buying old discontinued worn out junk at higher cost.
Postby yeshelp » 08 Jan 2025, 22:59
Well once again you practice is very responsable. I think it could be a good idea for future. It sucks to realise i have a system it rare pieces to replace.
At the moment i roll with my central powered wheel for summer and it is a pain to move on ice. no traction. With snow about to come again i need to get my winterchair back in operation . i feel a solder would be the quickest because buying and install a new system would take time and planning for me.
I will ask for ideas in my other post on how to solidify at least a bit the wire cable since the protector is cut and the tension relief is partly grinded down.
Thanks a lot
yeshelp
Postby Burgerman » 08 Jan 2025, 23:28
Theres a very scarce redel cable here https://www.ebay.co.uk/itm/126639068319
At the typical crazy price you pay for old no longer made stuff...
Remember that for a tiny bit more I got a 120A R-net power module, a brand new R-net joystick and a seating/lighting module, AND a free bs cable!
Now you see why it doesent make a lot of sense. Your repair is not reliable as it raises many stressed edges and its old and brittle.
Heres a cable and joystick, used 135 uk pounds.
https://www.ebay.co.uk/itm/333751414519
Postby martin007 » 08 Jan 2025, 23:36
Does that connector have a name or is it just a proprietary?
Postby Burgerman » 08 Jan 2025, 23:43
redel
See my links 2 posts above.
Postby martin007 » 08 Jan 2025, 23:54
It's a redel connector, but...
...it's an a la carte design that that isn't produced.
Postby Burgerman » 09 Jan 2025, 12:00
martin007 wrote:It's a redel connector, but...
No. You can buy them. ££££££££££ $$$$$$$$$$ and then are impossible to assemble at home... And many combinations and specialised wires... For a one off and practical purposes its not worth the cost and issues.
Cheaper to buy common r-net parts if you learn to use ebay properly.
For e.g. I wanted a "attendant" joystick.
I only buy new or at least AS new.
They sell for 135 to 400 pounds on eBay... Crazy to me. But I just check OFTEN and watch carefully in many countries and a huge number of search terms. When one appears that is way too cheap, I dont buy. I make a 50% offer. Or wait until it FINISHES and then do so by contacting seller.
So when one of these appeared yeterday and was NEW for £40 delivered, I offered 20...
And won it super cheap.
Offer
Accepted
Postby Burgerman » 09 Jan 2025, 12:03
More stuff I already bought silly cheap by learning to "fish" on eBay...
The total price is under £1k for ALL ofthe following combined:
Enough to fully equip 4 complete rehab powerchairs from scratch sat on my shelf!
FOUR of the 120A R-net power modules not new, but they all look it!
THREE of the fancy CJSM2 joysticks. All brand new.
ONE of the CJSM1 joysticks, new.
TWO of the LED joysticks both brand new. One with lights buttons, one without.
FOUR of the ISM6L seating and lighting modules. 2 new, 2 used. Some included full seating looms.
TWO of the multi bus cable blocks.
A huge box of battery loom and bus cables of various lengths all tessted and with 150A fuses. All used. But cleaned/exmined and look new.
An attendant R-net Joystick, just bought below:
An IOM module.
An R-net gyro...
This week alone I paid £50 for brand new R-net LED joystick.
And...
And £50 for a R-net 120A power module complete with another R-net ISM6-L seating module, and a "free" bus cable! :shifty:
Postby Burgerman » 09 Jan 2025, 12:07
Some of it...
Postby Burgerman » 09 Jan 2025, 13:04
Heres another I won on an £80 offer, brand new a few months ago.
Postby Burgerman » 09 Jan 2025, 20:11
https://www.wheelchairdriver.com/board/ ... 39#p207007
these 4 items all arrived today.
Power module, cable, and seating module all used and from 2017 but look brand new and shows low hours.
Joystick still sealed in original packaging so obviously brand new. It does seating, profiles etc. (Not lights).
Power module and seating/lighting module and cable all tested out as working and now programmed as a spare. So plug and play.
Full system, for a chair with lift, tilt, recline, power foortrests, and a 120A control system. For £100 brand new. Whats not to like! :clap
Postby yeshelp » 10 Jan 2025, 23:18
HI when you say you fish in other country,
does it mean that you go to different ebay. com ebay .ca ebay. uk ebay. ?
or do you mean you use yandez, find the translation in russian for example and search ebay.uk with russian words?
yeshelp
Postby Burgerman » 11 Jan 2025, 00:10
I search half a dozen other country eBays.
Sometimes you can do this from ebay UK too.
Postby yeshelp » 21 Feb 2025, 23:42
Hi
I just found a guy in my city that is part of an organisation that receives old wheelchairs and electronics to be recycled and he told me that if i give him the part numbers i need he could check it out and see if he can get me items free.
So that is an offer is hard to refuse as would vito coleon say. :ak47
So for my quickie 646 se serial number show in opening post , what are the pieces i could ask for that would be most helpfull?
Personnally i feel like getting a backup joystick and probably motors would be the most helpfull since i can not come up to him with 10 items, overwelming him .
What is the number of the j[b]oystick i am using? see pict?[/b]
also for the motors, it might me more difficult since from what i understant there are different CPU modules. I dont know if all motors are compatible with all cpu modules maybe because of connector ? I do not know . What i do know is that the chair serial number of my chair has never had any electric replaced(only the joystick has been resoldered.) What are the motor name number i can ask for that would be compatible?
any other parts I would be wise to ask for?
yeshelp
Postby Burgerman » 21 Feb 2025, 23:50
There are many power modules, especially pilot plus ones, as well as pilot plus joysticks and those are all original PG Drives parts.
Yours is a rebranded version of one and we never saw those here. Other will know what they are called and they are compatible.
So you want ANY pilot plus joystick, or any whatever those are called (qtronix or something).
A Redel cable. Or two...
Any pilot plus or "qtronics" power module but get the high powered ones, 100A preferably.
In order to use ANY new power module you will need to correctly set the motor compensation and brake voltage in programming. Which needs an OEM level programmer.
Postby yeshelp » 23 Feb 2025, 02:11
Are power module something that break easily? if not maybe I will try to focus him on looking for qtronix joystick .
The person needs part number . so here is a pict of my 2 qtronix stick (at bottom)
PG Drive technology
D49780 /09
J3080156
PG Drive technology
D49779 /06
J7050301
Is there a way to have all the numbers corresponding to the qtronix Joystick?
I imagine there are more than 2 ..
yeshelp
Postby Burgerman » 23 Feb 2025, 02:37
No he doesent need a part number.
ANY Qtronix or Pilot plus joystick, and any redel cable will work. Thousands of different numbers!
Users browsing this forum: acid_coke, sergey0, Superchunk and 382 guests
