Burgerman wrote:The non branded version, was called the Pilot Plus.
Those come with no lights or seating options and just speed settings.
Or with lights etc, all will work just the same.
https://www.ebay.co.uk/itm/235732945854
Overpriced by around 5 times but new.
https://www.ebay.co.uk/sch/i.html?_from ... &_osacat=0
They are all now old. And overpriced used unreliable junk. If you find one as new then it will be 4x the cost of a R-NET one...
I can find R-NET led joysticks unused, for £45 and 90A power modules for 40 to £50.
ex-Gooserider wrote:Used ones do still work... The Pilot+ branded joysticks usually had plugs in the body rather than the cables like the Qtronix rebrands... the big problem is that it can be hard to find the cables... ANY Pilot+ brand stick will work on those chairs, the only other issue is the mounting hardware is different, so you will need to make / purchase something new.
For my comprehension, r-net are like less old than what i have so there are more online to buy because still in production so more availaible correct?
they are still 600us new, 300 us 200 used. I do like that the wire is replacable .
For knowledge, if going that route , i need to change the power module wich is the computer at the back of the chair correct?
Does it fit in my chair? would the motors and all the other stuff be able to plug in . Compatibility issues. ( in dont need incline or leg lift)
martin007 wrote:It's a redel connector, but...
...it's an a la carte design that that isn't produced.
Users browsing this forum: Bing [Bot], duke1, emilevirus and 172 guests
