woodygb wrote:For programming , the SOLO requires the INDUSTRIAL Software.
It has two 75Ah batteries which after standing for 3 or 4 hours after charging both measure 12.55v.
Both batteries hold up when a battery load tester is applied across the terminals.......so the batteries are not new but appear OK.
By 'hold-up' I meant that with a battery tester attached and then the 'load' switch pressed for 8-10 secs, the voltage drops slightly but holds steady at the lower end of the section marked 'good'.
Users browsing this forum: Seafighter, shirley_hkg, tettralytic and 288 guests
