Mr TT wrote:I have 2 wheelchairs one is a BM style wheelchair with 8 mph motors and an R-net system like your BM1, with a lithium battery pack. If I read from the controller, and then try to write it straight back again I get this error message. If I do the same with my wheelchair I don't get the problem, so it must be a problem in the programming specifically to do with this chair?
Do Rnet 90A's electronics support max 36V as Rnet 120A?
Do Rnet 90A and Rnet 120A use the same joystick? Can these joysticks be swapped between them?
Do Rnet 90A and Rnet 120A use the same connectors? Can these connectors be swapped between them?
Do Rnet 90A and Rnet 120A use the same power and motor connectors as VR2-90A?
Can these connectors be swapped between Rnet 90A/120A
and VR2-90A
His "error" is that one of his power modules wont accept that he has set the motor output voltage higher than its firmware will allow. I think!
emilevirus wrote:His "error" is that one of his power modules wont accept that he has set the motor output voltage higher than its firmware will allow. I think!
If I set voltage too high, it'll just revert back to the default 22v. No error, nothing. On Sunrise, the limit is 26v. On my magic one, I set 31v and it saved just fine. Some companies hard locked it in the firmware.
Thanks BM, I have some more questions:
How to detect if a Rnet joiystick (the one without screen) is pure PG and non-permobil?
How to detect if a Rnet 120A power module is pure PG and non-permobil?
Is the the Rnet OEM dongle is still buyable in 2025?
How to detect if a Rnet dongle is true OEM?
CPguy wrote:I have a question regarding the R-Net battery connector on the A120 power module. Is that a generic connector (will an "Anderson SB 50 grey" fit?) or do I need a special connector on the power module side?
item 4 20011035 R-Net loom with angle plug, 300mm £29.50
Users browsing this forum: shirley_hkg and 192 guests
