emilevirus wrote:I'm curious. What are your cons of a Bounder?
Jay_x wrote:I am once again in the market for a chair. These are the RWD chairs I am looking at.
Magic Mobility V4: look like a great chair, no high speed package available though, which is important to me
Fusiongoat wrote:Jay_x wrote:I am once again in the market for a chair. These are the RWD chairs I am looking at.
This hasn't been available in the US for a couple of years. Magic Mobility only sells MWD and 4x4 in the US now https://www.sunrisemedical.com/power-wh ... c-mobility
Burgerman wrote:The reason 8mph is scarce is the same reason that off road and speed doesent work. Its just not a good idea. For a bunch of reasons. 6 to 7 is the best balance of torque needed for heavy rehab chairs with 24V and the usual controller/battery/wiring constraints.
Its much easier to make a scooter/4x4 magic or the invacare version, type thing like the X8 is. As it eats way less battery than something thats tank steered and especialLy so off road. But then its not a wheelchair, cant turn in place, cant really be used as one.
To make a true off road 4x4 wheelchair with skid steer etc then you are looking at 48V system, maybe the 230Ah batts as a minimum, and say 120A with a 6mph speed. Tank steer NEEDS to be low geared like 3 to 4mph, and get that 6mph back from double the typical 24V level.
robert97 wrote:With inspiration and construction details from Burgerman,
I built this wheelchair from a Permobil C350.
It does great indoors.
And outdoors it is super on rough terrain including
sand, gravel and snow .
It goes fast : 15mph
The main parts added to Permobil C350 are:
Roboteq hdc2460.
Lithium LiFe cells (5x14) 46 volts .
Apem3000 joystick.
Carlisle turf master 15 x 6.00-6NHS tires
Permobil earlier Street was even better.
The first Will's chair .
shirley_hkg wrote:https://youtu.be/d-ambztBMy4?si=nvkREfueF4EoGCl5
Wow, 8.5 mph and great suspension?? sign me up. and now its not available. that is exactly the chair I want right there. Actually I think he mispoke, Permobil chairs only ever went 7.5 mph as far as I know
robert97 wrote:C350: 15mph with Roboteq hdc2460. and 46volts.
yes, tilt, recline, foot plates are all working .
suspension is the same.
Users browsing this forum: acid_coke, emilevirus, Raro, shirley_hkg and 75 guests
