13x5 rims for Bounder
Re: 13x5 rims for Bounder
Postby LROBBINS » 25 Nov 2025, 19:55
Shirley,
I wouldn't bother with bolts to attach the disc to the wheel, just the bolts through disc and wheel and into the motor flange. Clamping force should keep the whole assembly together, but if you want some extra protection you can use some epoxy between the outer disc and the wheel so that "buttons" of epoxy fill the outer set of holes in the wheel. If really fussy you can use scotch brite to remove Al oxide before smearing on the epoxy.
Postby shirley_hkg » 26 Nov 2025, 02:48
Understood.
Postby shirley_hkg » 26 Nov 2025, 03:36
Tyre and rims are £30 per set here.
Postby Burgerman » 26 Nov 2025, 09:31
The tyres are very low quality compared to the Duro 120/70 - 8 or 110/80 - 8 though.
I have some... They have little "strength" and change shape and diameter as you change the pressure! They look good. But...
Postby shirley_hkg » 26 Nov 2025, 10:08
I might have been in the wrong way.
He wants knobby tyres for rough terrain. All those aggressive tyres are to fit
6" wheels.
Postby emilevirus » 26 Nov 2025, 15:31
Yeah, those slick tires won't do well in snow! I need knobby tires. So I guess I'm stuck with 6" rims then?
emilevirus
Postby Burgerman » 26 Nov 2025, 15:46
No
There are 8 inch off road type tyres.
E.g https://www.gopowersports.com/15x5-5x8- ... Country=GB
Same diameter as the K-Shield ones on the 6 inch rims.
Postby emilevirus » 26 Nov 2025, 15:48
But that's 15". I doubt the motors will like 2" more.
emilevirus
Postby Burgerman » 26 Nov 2025, 15:51
Its not 2 inch more...
Is this for a bounder?
Its 1 inch taller. The axle is in the middle right? tyre itself actually sags a little with low pressures too so probably little difference. In any case the bounder can swap sprockets so you can lower or raise gearing that way to suite yourself.
Amazon, same size.
Snow tyres...
https://www.amazon.co.uk/Carlisle-Snow- ... B072LNXVDB
Postby shirley_hkg » 26 Nov 2025, 16:28
Itsn't it say 6" rims ?
15*5.00-6
Postby Burgerman » 26 Nov 2025, 17:11
What he is worried about is that bounders use pretty small 13 inch rear wheels.
But most of the tyres we all fit tend to be 14.5 to 15 inches. But the difference isnt great because while a 13 inch wheel is 2 inches smaller than a 15 thats only a ride height difference of a single inch. Which is barely noticable.
Postby fishinjunky » 26 Nov 2025, 17:26
Brilliant. A disk on the outside.
Flat head bolts to secure the outer disk and wheel first.
Another set of holes on the disk 4 ∅5/16 THRU PCD ∅2.75" to match the drive hub.
Centre hole matches the hub to share load too.
Do you have a picture example of the disk? I'm thinking about doing this to my Bounder. And where online could I get the holes cut in the disk. Or could you find the disk an have it modified there and be shipped with the rims?
Postby shirley_hkg » 27 Nov 2025, 02:58
Burgerman wrote:What he is worried about is that bounders use pretty small 13 inch rear wheels..
It says 145/70-6.
So we should be getting 6" rims, instead of 8.
Like the one belows.
Postby shirley_hkg » 27 Nov 2025, 07:29
Would anyone reassure the measurements are correct please ?
Gonna get a rims and fabricate a adaptor disk .
Postby shirley_hkg » 21 Dec 2025, 13:45
Oil and grease dissolve rubber. Alkaline attacks aluminium.
What grease should be used in mounting tubeless tyres ?
Is Silicon grease appropriate ?
Postby Burgerman » 21 Dec 2025, 14:48
I used it in the past. Also used "swarfega" hand cleaner. Really you should use proper tyre mounting lubricant. I recently got a tin, in black...
Postby shirley_hkg » 26 Dec 2025, 14:45
Mechanic insists to retain a lid to support the rims, though very little room there.
Postby shirley_hkg » 26 Dec 2025, 14:49
Ready to install.
Users browsing this forum: shirley_hkg, Superchunk and 61 guests
