emilevirus wrote:Done.
fishinjunky wrote:emilevirus wrote:Done.
What size tires fit these rims?
Product title: Pack of 4 tires KENDA 145X70-6 2PR SCORPION K290
fishinjunky wrote:@shirley_hkg what is the price for the rims with knobby 13x5.00-6 tires and shipped to the U.S?
A gearing sprocket change from 19 to 23 is a 20% change. So 20% faster/slower. Your 11.5mph with 11.5% bigger tyres cannot be correct. How exactly are you determining this?
Stock tire was 4" width but I think it had more contact to the ground. New tire may be 6" wide but if only 3" is actually touching the ground that'd make the motor pull less amps no?
Even if it DID pull a couple of % more amps, it does so to compensate. So it wouldnt change the speed. Only the range. Again how are you measuring speed?
What is that? 70?
Users browsing this forum: Bing [Bot], Juggler258, tettralytic and 960 guests
