Postby wheeliechair » 13 May 2012, 18:37
I got the cord that was mentioned and I cut the end off and there is no green wire just red, white and black?
wheeliechair
Postby woodygb » 13 May 2012, 18:46
I've come across the 3 wire myself...
Assume that black is gnd / common / neg and connect the other 2 wires together.
Postby woodygb » 13 May 2012, 20:10
So far with all the 3 wire leads I've done this rule can be followed....
Assume the Black is always GND and the other two wires ...by default...must be RX and TX.
The only other way to be sure is to pop the case and look at the colours soldered to the 3 pads ... GND , RX and TX.
Postby malamar » 18 May 2012, 08:26
By post yesterday a new silver and black snake of very nice craftmanship entered letter box; looks intimidating....
Thanks Woody....God bless You !!
PM following in due time.
Have a good day
malamar
Postby woodygb » 18 May 2012, 10:11
Excellent news that it arrived safely.
I'd like you to be satisfied that it works before arranging payment ... "try before you buy"....so install the software and give it whirl.
Cheers Woody
Postby wheeliechair » 23 May 2012, 18:45
woody I am having the same trouble that brax had I have the cable soldered the driver installed and it passes the loopback test and when I open pgdt programmer it says not connected for a second then it says comms inactive.
My chair is a quickie s646.Can I send you my cord and you send me one of yours?
wheeliechair
Postby woodygb » 23 May 2012, 19:12
I have NO USE for the programming lead ..it was simply a project that I set myself to aid this community..and Brax's problem was ... if you like ... a part of the initial project.
Unfortunately I have no idea why his lead worked fine for me and vicer versa.
So ....
I can offer to look at your lead and try it myself IF you cover postage...
OR
I can buy in / purchase a lead ( that currently works ) from my Ebay source ..construct one and SELL it to you...at no loss to myself/minimal profit.
Cheers Woody
Postby woodygb » 23 May 2012, 19:54
Wheelie ...
It should be noted that the two lead types I purchase and convert are thru Radio Arena UK and both ...if my Googling is correct ...made by RAYTALK.
I did purchase a MUCH cheaper version .. also Chinese and KPG-4 / 46 ...to try ...and it ...like yours.... passes all the "tests" but will NOT connect as a single or one wire interface.
Postby woodygb » 23 May 2012, 20:05
Postby wheeliechair » 23 May 2012, 23:37
Okay, just tell me how much it will cost to buy one from you and where to send the money.
wheeliechair
Postby woodygb » 23 May 2012, 23:43
The lead and plug I purchase as needed via Ebay UK ..Next day delivery on the lead.
Kenwood KPG-4 Replacement USB RIB-Less Programming Cable
http://www.ebay.co.uk/itm/Kenwood-KPG-4 ... 564629dea2
£18.50
Approx £2.50 for the plug
So the parts cost £21 or $33
plus Postage and packing to you...and Paypal charges me to accept your payment .
The total cost will be close to $40 and I'm happy for you to recieve the lead and try it before paying me.
Your choice on paying upfront or "try before you buy"
Cheers Woody
Postby wheeliechair » 25 May 2012, 20:01
Okay, I will go with "try before I buy". I will PM you my address.
Thank You
Derek
wheeliechair
Postby woodygb » 29 May 2012, 10:49
Some people have been having problems with the Kenwood lead ... including myself with my new batch!.... SO ... a bit more research and a chat with Radio Arena plus Raytalk ( damn those leads are CHEAP direct ..but 50 at a time is to rich for me! ).. gave a new lead recommendation.
An Icom OPC-592 USB RIB-Less Programming Cable ..just 2 wires .. I've bought one and just tested it .. absolutely no problems!
So revised pic...old ones DELETED.
Postby Seajays » 30 May 2012, 23:43
SUCCESS! Well finally with the help of Woody and Gologen I got the program working to program my Pride Q 6000Z. I used my Windows 7, the USB - Can adaptor on page 15, post 68 and Gologens LXN4py2si.dil. I really would like to thank these guy's for all the effort they have put in to make this happen. The Pride owners can mow have a chair that works the way it should. Thank you Woody & Gologen
Seajays
Postby JoeC » 30 May 2012, 23:58
Great news!
I haven't been following this thread, so I don't have all the details. Does the programming interface look like it will give access to everything you'd want?
JoeC
Postby gologen » 31 May 2012, 00:08
You are welcome.
I'm glad you got results. Did you have a problems with wheelchair settings or something else ?
gologen
Postby gologen » 31 May 2012, 00:10
JoeC wrote:Does the programming interface look like it will give access to everything you'd want?
Only to controllers with CAN-bus interface
gologen
Postby woodygb » 31 May 2012, 00:17
It has now .. according to Gologen ..with the addition of some updates... got FULL OEM access to ALL settings.
Postby gologen » 31 May 2012, 00:20
For controllers with serial interface Tx-Rx you will need Woody's cable
gologen
Postby woodygb » 31 May 2012, 00:26
So just to make things clear ...Gologen has found a way to make a CURTIS/Pride Q-logic Canbus interface for the community ...the lead I've researched should work for PGDT ..Pilot+ ,VSI,VR2 , Solo etc.
Assuming that you can acquire the software....
Postby Seajays » 31 May 2012, 00:30
JoeC,Yes you can change all settings in the Pride Q 6000Z
Seajays
Postby woodygb » 31 May 2012, 00:42
Cologen ..your download link for the LXN4py2s.zip file doesn't seem correct anymore.
viewtopic.php?f=2&t=1965&st=0&sk=t&sd=a&start=280#p26975
Have you altered it?
Postby gologen » 31 May 2012, 00:49
It looks OK. I still can download it.
But any time we can reload it if will be need.
gologen
Postby woodygb » 31 May 2012, 00:57
Once unzipped ..I get a COM file
MS-DOS Application
lxwdpi2j.com
Postby Seajays » 31 May 2012, 01:00
Work for me just now and unzip right
Seajays
Postby woodygb » 31 May 2012, 01:07
MOST odd ..email it over to me please John.
UNZIPPED
Don't worry ...it's sorted now ..downloads and unzips correctly!
Postby gologen » 31 May 2012, 02:29
Just for info
1314 PCPS v3.12 shows "Quick setup" in table view incorrectly
This bug was fixed in the next version of program V4.1.0 (Build 527)
To change parameters expand group "Quick setup" (click "+") and you can change every profile separate (not in the table).
gologen
Postby gologen » 31 May 2012, 02:46
Other problem: v3.12 doesn't work with text parameters. So text parameters can't be readed and changed.
I.e. If you try to get "Remainder" - "User Text" you get ERROR. In version 4.1 this bug fixed.
gologen
Postby woodygb » 02 Jun 2012, 11:50
wheeliechair wrote:woody I am having the same trouble that brax had I have the cable soldered the driver installed and it passes the loopback test and when I open pgdt programmer it says not connected for a second then it says comms inactive.
I have a lead made up for you...but .... you might like to try this mod to yours first.
Postby woodygb » 02 Jun 2012, 12:42
diode addition.JPG (37.11 KiB) Viewed 11723 times
Users browsing this forum: duke1, emilevirus, LROBBINS, Superchunk and 301 guests
