Do not forget me, please
Giordano
Burgerman wrote:I just made 2 leads. Neither communicate. Both install, and have tried ports 1 to 8, and the program sees the USB adapter/port. But says Comms Inactive... Very odd since Woddys original cable/driver worked perfectly. Whats different?
Do all of these need the same/different drivers (all my machnes are 64bit win7)?
PL-2303 Driver Setup Installer, Prolific Edition
Setup Installer Revision Note History
System Requirement:
. Supports the following Windows OSes:
- Windows 98SE
- Windows ME
- Windows 2000 SP4
- Windows XP SP2 and above (32 & 64 bit)
- Windows Server 2003 (32 & 64 bit)
- Windows Server 2008 / 2008 R2 (32 & 64 bit)
- Windows Vista (32 & 64 bit)
- Windows 7 (32 & 64 bit)
NOTE: For Windows 7, please use RC build 7100 or above build version.
. USB host controller
. Device using PL-2303H/HX/X version chip
Supported device ID and product strings:
. VID_067B&PID_2303 for "Prolific USB-to-Serial Comm Port"
Driver Versions:
- Windows 98/ME Driver: v2.0.0.19
- Windows 2000/XP/Server2003 (32 & 64-bit) WDM WHQL Driver: v2.0.13.130
- Windows Vista/7/Server2008 (32 & 64-bit) WDF WHQL Driver: v3.3.11.152
Release Notes:
PL2303 Driver Installer v1.3.0
Changes from Installer v1.2.10:
Driver Changes -
- No driver change
Installer Changes -
- Fixed "Modify/Repair" Menu options to show correct installer version.
Installer & Build date: 1.3.0 (2010-7-15)
Language Support:
- English (default)
- Chinese (Traditional)
- Chinese (Simplified)
- Japanese
Prolific Technology Inc.
http://www.prolific.com.tw
I wish I knew! .... I've ordered from the same place each time ...I can only assume that I've recently got a different batch.What is different?
woodygb wrote:What is different?
I'm going to contact Brax ( he has the original ) and ask him to pop the lid on the USB plug and give me the number off the internal board..... I'll then attempt to chase it via the manufacturer who I believe is Maxton.
Users browsing this forum: rover220 and 681 guests
