This is a compilation of various posts by Gologen...together with a couple of mine that have instructions and the various file downloads.
First pic is of the Curtis/Q logic type programming plug.....
CURTIS SOFTWARE DOWNLOAD ..It's currently the only download link that I know of that is working... just read the page carefully and select the ...
hard to see ..correct download links ..and ignore the adverts.
http://www.yourfilelink.com/get.php?fid=786915Gologens post on his success in getting connected and programming.
Today I tested my USB-CAN device in Windows 7(64). When i connected USB-CAN to USB port Windows found and installed usb-serial driver automaticaly. I run program 1314 PCPS with no problem.
So: 1314 PCPS + my dll +
USB-CAN can work in Windows 7(64).
I want to post my dll file on this forum. May be it can help somebody.
So if you have or planning to buy this device
- usbcan.jpg (70.54 KiB) Viewed 39038 times
You can use this file to get connection 1314 PCPS to curtis controllers with CAN-bus.
Name of this file is LXN4py2s.dll. You should unzip and copy this file to program's folder (C:\Program Files\1314-4401 PC PROGRAMMING STATION\) and change
original LXN4py2s.dll (NetPorty driver).
download/file.php?id=1594Next. You should copy file QM_USB.dll (USB-CAN driver) to same folder. You get this file from seller when you purchase USB-CAN device.
QM_USB RAR File
Other steps to get connection to controller
you can find here:
viewtopic.php?f=2&t=1965&st=0&sk=t&sd=a&start=216
