by ex-Gooserider » 13 Mar 2013, 06:47
It may be an adjustment issue, but it may also be normal... My 2010 Braun / T&C has power deployment and unfolding until the inside section is at about 45* out, then the motor cuts out and gravity takes over. When the end of the ramp touches down, it is often not fully unfolded, especially if exiting onto a sidewalk or other situation where the place the ramp touches is higher than the tire contact patch.
Usually the ramp continues to unfold and flatten out, with the end sliding across the ground, but if it's a rough / sticky surface (like grass) it will sometimes get stuck... Not a big deal though, as I've found that as soon as you put any weight on it with your chair it will flatten on out with no problem...
However it wouldn't hurt to run the situation by your dealer, or call Braun tech support to see if they have any more detailed suggestions.
