Munkypoop99 wrote:they told me those aren't air filled, GRRR! I think foam filled or something. I don't know. But I was originally going to switch to air filled and told them I don't want to anymore, so they said pneumatic, HMMMex-Gooserider wrote:I should point out that pneumatic tires ARE the same as air-filled ones... The WC industry uses split rims and tubed tires, which DO go flat quickly in the case of a puncture. However if you can find TUBELESS tires and compatible rims that you can make fit on your chair, there is much less of a problem with flats...
Barring a gross puncture of the sort that totally cuts the tire open, a typical small object will only give a slow leak - this is part of the nature of a tubless tire. If you use puncture sealing goo inside the tires the way that BM does, you are even less likely to have a problem.
The air filled tires will give you a much softer ride than the solids that the WC industry tries to stick people with.
ex-Gooserider wrote:Munkypoop99 wrote:they told me those aren't air filled, GRRR! I think foam filled or something. I don't know. But I was originally going to switch to air filled and told them I don't want to anymore, so they said pneumatic, HMMMex-Gooserider wrote:I should point out that pneumatic tires ARE the same as air-filled ones... The WC industry uses split rims and tubed tires, which DO go flat quickly in the case of a puncture. However if you can find TUBELESS tires and compatible rims that you can make fit on your chair, there is much less of a problem with flats...
Well, there may be confusion, either on your part or the vendors... At any rate air-filled and pneumatic are the same thing, as that is what pneumatic means... However a pneumatic tire can be either tube or tubeless. Tube tires will go flat quickly on any puncture because a tube is essentially a balloon, and will expand away from any puncturing object. Tubeless tires are much less of a problem because the inner layer of the tire that actually retains the air is bonded to the tire carcass, so it can't expand - instead it grips the puncturing object and tries to seal around it, giving you a slow leak. The puncture sealing goo helps even more by filling the leak entirely.
What you are PROBABLY getting judging from what you post is a "foam filled" tire - which is essentially the same tire with a hard foam rubber insert filling it, instead of air. This is what some of us also call a "solid" tire. These can't go flat, but they give a harsher ride than a pneumatic, and have much higher rolling resistance than a properly inflated pneumatic. The tires that BM uses on his chair are actually "under-inflated" which again makes them harder to roll, but gives an even softer ride...
Burgerman wrote:Wheel = rim plus tyre.
Plastic wheels makes no sense. Tyres are rubber or rubber like. Wheel rims are plastic or metal.
ALL high end powerchairs use metal. Usually aluminium alloy, usually cast and 2 bits so tyres can be fitted easily.
Now, your wheels are metal. Your tyres are rubber. This goes without saying.
Types of tyres.
a) Air filled (pneumatic) tyres with tubes like a bicycle. These are common. Can be grey, or black. Good for range, and can get punctures.
b) SAME grey or black tyres, but filled with a kind of foam rubber. Sold as flat free, or similar. These cannot get punctures. But they give a considerably harsher ride and are heavier, and tend to eat batteries faster. They wouldn't be my choice.
c) TUBELESS air filled (pneumatic) tyres. These are approx. 20 times less likely to suffer deflation due to punctures. As used on my own powerchairs, and all modern cars and fast motorcycles. They work the same as any air filled tyre. Not generally fitted to stock powerchairs. They are much more reliable than tubed tyres.
d) Foam rubber tyres. Only used on toys or really small indoor only chairs. Not recommended!
Air filled tyres can use puncture seal. This is a liquid that seals punctures as you drive about automatically. Works much better on tubeless tyres.
Users browsing this forum: Burgerman and 59 guests
