cdb0ewm wrote:I am putting together a 24v Headway setup using 8 packs of 8 cells each. If I understand the wiring diagram above showing the balancing wiring configuration, will I be basically duplicating it, one for each set of 12volts. Since the Hyperion charger has 2 plugs/harnesses for balancing, for the second 12volt set should I use the second plug on the Hyperion charger or do I do it all with one plug.
Burgerman wrote:I thought they were an oddball size. Meaning replacing wheels with standard inch diameter/width versions.
bulldog wrote:Hello i wand to buy other tires for my alber adventure BLACK size 90/70-10 et 75/70-6 it is possible to put another size on this wheelchair ??? thank you
Burgerman wrote:Are your wheels 10 inch diameter?
If so there are lots of tyres. http://ssl.delti.com/cgi-bin/rshop.pl?d ... htweiter=1 for eg.
expresso wrote:http://www.alibaba.com/product-gs/896831161/12v60ah_lithium_ion_battery.html
would something like this work - some benefits ?
but it would cost somewhere around $2500 for each battery in a group 24 direct replacement - if thats even true - i wouldnt know all the details involved like you would - i didnt bother looking into that - just the price alone - isnt worth it for me
maybe someone would wake up and build them the way you lay it out on your webpage and make it a direct replacement one day -
expresso wrote:i dont know - i figure it would be some benefits to it - if in fact they were the correct specs for a direct replacement - since they are not - its a NO Go - i did find a site which can make a set of batteries depending on your Group size etc,
the only way this would be worth it for me - is if the prices are reasonable - meaning not much more than the reg. lead batteries wet get today - and also if i had to pay for them myself out of pocket - then it would be wise for me to do like you do and build them correctly even if it costs more up front -
Users browsing this forum: jehan, LROBBINS, Seafighter, shirley_hkg and 593 guests
