The holes are 4 mm OC apart and 8 mm up from the centre of the bottom pin
woodygb wrote:Cologen mentions that he used two pins from a plug that he had kicking around that fitted nicely in the joystick socket.
.If you read this manual I believe you'll see that it is not part of the Q-Logic family
Q-LOGIC MODULES
The basic system is a power module and a hand control. For adjusting seat position, an AAM module is added. For users who require specialized input devices, several options are available. This is a true plug-and-play system, and modules are simply daisy-chained together.
Power Module (CTLDC1466): The power module controls the brake and drive motors and is the master of the system. This is where most information is stored, and where all input and output signals are managed.
AAM (CTLDC1472): The Advanced Actuator Module (AAM) drives five actuators that can be used to adjust the seat, back, and leg positions of the chair.
ECU (CTLDC1486): The Environment Control Unit (ECU) drives eight relays that can be used to operate devices such as mechanical page-turners and speech synthesizers.
Hand Control (CTLDC1467): The hand control is a compact, ergonomically-designed input device with a joystick, switches, speed adjustment knob, audible feedback, and a high-resolution color LCD display that continuously keeps the user well-informed.
SAJ (CTLDC1469): The Stand-alone Joystick (SAJ) is a basic no-frills input device with a joystick, switches, and various LEDs providing feedback.
Attendant Joystick (CTLDC1469): The Attendant Joystick is physically identical to the SAJ, but differently programmable. It is typically mounted on the back of the chair, for use by a walking attendant. When it is switched on, it takes over control from the user's input device.
Enhanced Display (CTLDC1471): The Enhanced Display has a high-resolution color LCD display, built-in IR for remote control, and Bluetooth compatibility. As an input device, the Enhanced Display can be operated by remote switches or a joystick. It also provides an optional display for the SAJ.
Sip & Puff (CTLDC1487): The Sip & Puff is a breath-controlled input device used together with the Enhanced Display.
Handheld Programmer (ELEASMB5215): The handheld programmer allows you to adjust the system’s many programmable parameters. It is especially convenient for fine-tuning a chair while it is being driven to suit the individual user.
PC Programming Station (ELEASMB5216): The PCPS is a software program that allows you to edit, download, and upload program files and firmware between the system and a PC.
falco peregrinus wrote:This is unrelated to the present flow of this thread - sorry to interrupt. But this seems the best thread to put this request in. Could someone post a copy of a Pride Quantum configuration file for me please? I'd like to play with the software and get a bit familiar with it while I'm waiting for my CAN-BUS interface to arrive. Thanks.
Falco
update 4 or 6 depending on where you found the program.we are all using is 1314-4401, version 3.12, update patch 4.
You could always play with the MC-2 Simulation mode.
woodygb wrote:The latest 1314-4402 uses CPF files and PAR Files.
Users browsing this forum: LROBBINS and 361 guests
