If you don't believe me, then visualise that bolt even further to the side. Or mentally draw a line from bolt to the flat 90 degree sliding edge. That edge would need to be at about 5 degrees anti clockwise to give security.
That pivot bolt MUST be central, *(or the contact surfaces angled so that they are at 90 degrees to the pivot point at a tangent to an imaginary "circle").
One look at the videos will tell you I am correct. Saw the error as soon as I looked at it. Pretty obvious.
What's more, mine is the same. So I tested it hard. If I try, full power reverse chair, and parked on an uphill section of road I too can reverse out if I rock the chair! It pushes the spring out of the way as the geometry forces the latch to open.
Like this.
http://www.youtube.com/watch?v=NsYqJ-l3 ... e=youtu.beAs usual, I will need to repair it properly myself because this is an accident waiting to happen.
For EG, at a busy junction. Waiting to turn onto a main road from a side road on an uphill slope. See gap, gun van, roll into the back and cannot steer or stop...
Why would they not see this? And its not just one manufacturer since they all copied the same error from each other!
