Q LOGIC PROGRAMMING INTERFACE
Postby vinsen » 28 Dec 2013, 14:36
woodygb wrote:USB\VID_ 1FA1 &PID_ 00C8
Everything looks fine in your pictures.
Your lead should now show up as Curtis 1309.
BUT your user level will be low as I do not know the extra embedded code .
No driver in the Task Manager on port 8 are as ft232. I can not understand how to save changes VID PID ?
vinsen
Postby woodygb » 28 Dec 2013, 14:47
PARSE PROGRAM.png (64.03 KiB) Viewed 14743 times
Postby vinsen » 28 Dec 2013, 14:51
woodygb wrote:.
Well I understand. changes need to save themselves. In what file to call him and put in what folder?
I saved and called D - is that correct? The question then becomes how to deal with driver settings?
http://fotki.yandex.ru/users/volga-volga2/view/489261/
vinsen
Postby woodygb » 28 Dec 2013, 14:52
CURTIS.zip
(856 Bytes) Downloaded 683 times
Postby woodygb » 28 Dec 2013, 15:01
I don't think it matters where you save the files ... the LEAD/CHIP is programmed with a new VID and PID ..Windows should find it and use the info from the Curtis program to assign it's parameters.
Postby vinsen » 28 Dec 2013, 15:02
woodygb wrote:.
CURTIS.zip
this saved file you want to replace and delete the file nastroyyki driver?
http://fotki.yandex.ru/users/volga-volga2/view/489262/
vinsen
Postby woodygb » 28 Dec 2013, 15:06
open FTPROG
Parse chip
Program chip
exit FTPROG
Check that the chip has been programmed.
open FTPROG
Parse Chip ...to check that new VID and PID has been retained.
Postby woodygb » 28 Dec 2013, 15:08
vinsen wrote:
woodygb wrote:.
CURTIS.zip
NO NO
That is the FTDI Chip parameters for the Curtis 1309... they seem to match yours...but it's only a saved parameters file and NOT needed for the lead/chip to work.
Postby woodygb » 28 Dec 2013, 15:12
You may need to restart your computer to get the lead to install as a Curtis 1309.
Postby vinsen » 28 Dec 2013, 15:41
woodygb wrote:open FTPROG
Parse chip
Program chip
exit FTPROG
open FTPROG
Got it! The settings are saved!
http://fotki.yandex.ru/users/volga-volga2/view/489264/
http://fotki.yandex.ru/users/volga-volga2/view/489265/
vinsen
Postby woodygb » 28 Dec 2013, 16:11
Windows should now call your chip a Curtis 1309.
Postby vinsen » 28 Dec 2013, 16:46
So. In short, all earned. BUT! On the program Curtis PC Programming Station 1314-2201 v3.12 Patch4 starts up without errors connects all works.
CURTIS usb Every time you start the program generates an error. BUT! Hookup is! All settings are changed everything works.
You just happen?
http://fotki.yandex.ru/users/volga-volga2/view/489276/
http://fotki.yandex.ru/users/volga-volga2/view/489277/
http://fotki.yandex.ru/users/volga-volga2/view/489278/
http://fotki.yandex.ru/users/volga-volga2/view/489279/
http://fotki.yandex.ru/users/volga-volga2/view/489281/
CURTIS USB - ERROR :(
DRIVERS - FT232-CURTIS
http://fotki.yandex.ru/users/volga-volga2/view/489290/
http://fotki.yandex.ru/users/volga-volga2/view/489289/
http://fotki.yandex.ru/users/volga-volga2/view/489288/
http://fotki.yandex.ru/users/volga-volga2/view/489287/
vinsen
Postby woodygb » 28 Dec 2013, 16:57
Correct.
I cannot get further...
MORE information is needed to get from USER to OEM ... and I haven't found it.
My Image.
Postby woodygb » 28 Dec 2013, 17:03
I see that your BOTH your versions are Dealer not OEM.
Postby woodygb » 28 Dec 2013, 17:13
That is all I can do for you.
Postby vinsen » 28 Dec 2013, 17:31
Let us think what it means and how to fight. THANK YOU FOR YOUR HELP :) !!!! With the upcoming holidays!
vinsen
Postby vinsen » 29 Dec 2013, 08:00
Good afternoon.
Returning to the adapter CAN-USB viewtopic.php?f=2&t=2757&start=20 . I did not understand the person on the photos of all the works ? There are no errors ?
vinsen
Postby woodygb » 29 Dec 2013, 11:06
Good MORNING :)
The CAN BUS interface that is used on the wheelchairs works with no problems using the earlier 1314 programming station.
It emulates the NetPorty interface ... one of the first CAN BUS interfaces used by Curtis .
NetPorty.zip
(116.33 KiB) Downloaded 546 times
It is the work of Gologen.
You can use this file to get connection 1314 PCPS to curtis controllers with CAN-bus.
Name of this file is LXN4py2s.dll. You should unzip and copy this file to program's folder (C:\Program Files\1314-4401 PC PROGRAMMING STATION\) and change original LXN4py2s.dll (NetPorty driver).
Next. You should copy file QM_USB.dll (USB-CAN driver) to same folder. You get this file from seller when you purchase USB-CAN device.
Other steps to get connection to controller you can find here:
viewtopic.php?f=2&t=1965&st=0&sk=t&sd=a&start=216
Before you start download please read:
1. My dll doesn't use all functions of original NetPorty. Just only functions used by 1314 PCPS. So. It is not full analog of NetPorty and cann't be used in other applications.
2.File was tested in Vista (32) and Windows 7(64) only. I guess, it should work in other Windows, but i didn't test. Who will test please post results.
3. I wrote this file for my own needs and i didn't use the protection from misuse (with other devices and without devices it can give crash of program). I got needed results and i stop work on this project.
4. And last one: You use this file AT YOUR OWN RISK
If you read and agree, please download and use it free:
LXN4py2s.zip
You might want to private message Gologen ( Gennadiy ).
He is ...I believe.. also Russian and living in Canada. (memberlist.php?mode=viewprofile&u=1290)
Postby vinsen » 29 Dec 2013, 13:45
As I understood on wheelchairs CAN bus is the joystick .
vinsen
Postby vinsen » 29 Dec 2013, 14:05
..............I understood correctly adapter CAN only needed for connection with joysticks - wheelchairs ? And the USB cable in all other cases .
vinsen
Postby woodygb » 29 Dec 2013, 14:20
Only the Curtis enAble® 50 and MC-2 wheelchair controllers uses CAN BUS for programming...
Pride wheelchairs use Q logic ...which is a Q-logic joystick + Curtis enAble® 50 controller .
Some Ottobock wheelchairs also use the enAble® 50 controller but I think that they use a Curtis joystick.
I believe that the enAble® 40 controller just uses the standard RX and TX Serial connection for programming.
http://haesung1.mireene.co.kr/ACTech/pr ... Manual.pdf
Postby woodygb » 29 Dec 2013, 14:25
So ..to try and make it clear ... the Curtis controller is programmed through or via the joystick .
This is standard practice on most ..if not all .. makes and models of wheelchair controllers not just Curtis .
CAN BUS is a communications protocol that allows various parts to be easily added so that they can all talk to each other...
The configuration is Master ( possibly the joystick ) and Slaves .
Postby woodygb » 29 Dec 2013, 14:38
I see that Gologen is here/online ...hopefully you have the Russian language in common.
Postby vinsen » 29 Dec 2013, 15:17
Now .Понял .Thank you for the clarification .
interesting and ебей you can buy a cable for a new program Curtis ?
Спасибо !
vinsen
Postby woodygb » 29 Dec 2013, 15:30
SHINTOOL MACHINERY CO., LIMITED quoted me $380 U.S. dollars for the NEW 1309 USB lead .. OEM level.
Postby vinsen » 29 Dec 2013, 15:35
woodygb wrote:SHINTOOL MACHINERY CO., LIMITED quoted me $380 U.S. dollars for the NEW 1309 USB lead .. OEM level.
This is the price of the cable ? :shock:
vinsen
Postby woodygb » 29 Dec 2013, 15:38
YES.... and before you ask ..NO ..I didn't buy it.
1309 PRICE.jpg (203.73 KiB) Viewed 14330 times
Postby vinsen » 29 Dec 2013, 15:44
http://www.shintoolparts.com/product.asp
We have done ...........it just takes time . Expensive for the cable .
.............Maybe this is the price for the CD and cable ? .
.........And in General on this forum this cable someone who has ? Show the insides of this cable .
vinsen
Users browsing this forum: faico_26, jefferso, shirley_hkg and 462 guests
