bgmen wrote:October will stop reading the topic first as
collect £ 25 cable and I'll write to me a
The original cable I made after following your instructions worked perfectly until the other day when I accidentally ran over it. If that wasn't bad enough I ran over it again for a second time the other day and when I went to check on my new build I couldn't get it to read the joystick/power module.
Burgerman wrote:Pleased to hear it.
You had torque set to zero (meaning it would send no amps???) Changed to 100.
And I changed the inhibit settings from:
low 0 to 100 (in case you had an inhibit switch fault)
mid 50 to 100 (I may have left that one?)
high 100 to 100...
Users browsing this forum: emilevirus, fordragon88, Gnomatic, john66, Juggler258, martin007, Potty and 2670 guests
