Burgerman wrote:![]()
What Ah are your lithium batteries? I seem to remember you are using Pouch type soft case used A123 cells and lots of them? Does the fire risk with that type of call getting punctured worry you?
Burgerman wrote:Yes, basically full power (20 amps) regardless of capacity.
LiFe
3.600 Volts.
Correct cell count! 13 in my case, 8 in most others for 24v.
No time or capacity limit. (untick)
Correct Ah capacity, or up to say 30 percent less. It means the cut off point is later.
TCS 100
TCS END CONTINUE
The rest don't matter to most people so just ignore.
woodygb wrote:Your pic also seems to show numerous short circuit connections .
I think that this is correct ..BUT I could be wrong.
Users browsing this forum: shirley_hkg and 107 guests
