steves1977uk wrote:Would 20 AWG wire be ok for the balance cable?
ex-Gooserider wrote:Should be, as long as the length is kept fairly short... IIRC the Hyperion only balances at about an amp, which won't give that much voltage drop if you keep the total wire length short.... I'd say less than 3-4 feet total. (Make sure to count both the length of the harness in the chair as well as the distance between the chair and charger...)
I'd rather use18 AWG, but that is arguably overkill, and it starts getting to be a challenge to find connectors that both have enough pins and use wire that size. The big advantage of the larger size is that you can get away with a longer balance lead, which might make it easier to plug the charger in...
Burgerman wrote:It watches and displays cell voltage all of the time. It watches TOTAL voltage as it charges for 30 secs, and decides on how many amps, and then looks at cell voltages individually for 10 secs while it stops charging. And while charging if any cell exceeds the set voltage it sinks it by up to 300ma to hold it to the correct point, and throttles the charge amps back to whatever level is needed to ensure it can do so.
It does a few other things too. Long wires just extend charge time a fair bit if the pack is very far out of balance.
steves1977uk wrote:ex-Gooserider wrote:Should be, as long as the length is kept fairly short... IIRC the Hyperion only balances at about an amp, which won't give that much voltage drop if you keep the total wire length short.... I'd say less than 3-4 feet total. (Make sure to count both the length of the harness in the chair as well as the distance between the chair and charger...)
Hi ex-G,
The cable length won't be any longer than 3 meters, and the balance connector plug has 9 26awg (could be 28awg) open-ended wires that have solder on them already.
So there needs to be thicker cables from the battery pack, which are soldered onto the thinner balance wires for a more stable voltage reading? Have I got that right?
Thanks BM and all others for helping me to understand this and to get it right!
Users browsing this forum: acid_coke, Bing [Bot], jefferso, robertnew16 and 481 guests
