... I/you would need to ask Kas .. the developer ... for a copy of the RC Commander as I don't think it's exactly the same App that is currently available as a direct download for the Android phone.I like the version with the screen better
..So the VIDEO link and all the kit associated with displaying the video on the phone has NOTHING to do with the Arduino interface...YOU the end user would need to supply all the bits required ..I.E. Camera and WiFI link.The real time video is conveyed via Wi-Fi.
Bluetooth Modem - BlueSMiRF Gold
The Sparkfun BlueSMiRF Gold is the latest Bluetooth wireless serial cable replacement from SparkFun Electronics! These modems work as a serial (RX/TX) pipe. Any serial stream from 9600 to 115200bps can be passed seamlessly from your computer to your target. Units tested successfully over open air at 350ft (106m)!
The remote unit can be powered from 3.3V up to 6V for easy battery attachment. All signal pins on the remote unit are 3V-6V tolerant. No level shifting is required. Do not attach this device directly to a serial port. You will need an RS232 to TTL converter circuit if you need to attach this to a computer.
This is a single unit only. We recommend the purchase a USB dongle to interface to a computer if you do not already have access to a computer with Bluetooth connectivity.
Specifications of the Sparkfun BlueSMiRF Gold:
• FCC Approved Class 1 Bluetooth Radio Modem
• Extremely small radio - 0.15x0.6x1.9"
• Very robust link both in integrity and transmission distance (100m) - no more buffer overruns!
• Low power consumption : 25mA avg
• Hardy frequency hopping scheme - operates in harsh RF environments like WiFi, 802.11g, and Zigbee
• Encrypted connection
• Frequency: 2.4~2.524 GHz
• Operating Voltage: 3.3V-6V
• Serial communications: 2400-115200bps
• Operating Temperature: -40 ~ +70C
• Built-in antenna
Users browsing this forum: shirley_hkg and 138 guests
