Red Dragon wrote:what is better the oem or the manufacturer level access ?
In theory the "C" level "manufacturer" level is best, but for our needs the "B" or "OEM" level is just as good...
As I understand it, the Manufacturer level refers to P&G's own internal software that gets into fine tuning the inner workings of the hardware. OEM level is what is supplied to the chair manufacturers, to allow them to tailor the controllers to the specifics of their own chairs...
In practice, I'd expect all the controllers coming out of P&G to have been run through the manufacturer software to test them and make them as identical as possible - but that all the chair makers would get the same settings and configuration. (so would you if you were to get a system straight from P&G) My guess is that because of manufacturing tolerances there probably would be slight variations in the way different modules worked, and the manufacturing software serves to "tune out" those differences and make all the modules perform the same (and more importantly both channels in a given module the same)
The chair maker then takes the level B, OEM software and sets each controller to match the chair that it's being used in... What we want to fix is only the things the chair manufacturer changed so that level is all we need...
