Burgerman wrote:You better be quick, they are out of production.
Ah per mile 4.96
it used to be about 3.6 outdoors only
Burgerman wrote:There is a big capacitor in there that is fed an output voltage via a high value resistor from the supply, so it charges slowly. Plug in the output to a battery first and it takes hundreds of amps as it charges instantly. Leaving it connected shouldn't cause an issue.
Users browsing this forum: acid_coke, Bing [Bot], shirley_hkg, Yennek and 158 guests
