Burgerman wrote:There are good cells, and there are good chargers. And there are good ways to convert a chair. But there is no good simple way that's any good. No plug and play fit and forget solution for the average couldn't care less user. That said its all pretty easy ONCE YOU UNDERSTAND!
Burgerman wrote:http://www.wheelchairdriver.com/converting-to-lithium.htm
http://www.wheelchairdriver.com/BMS.htm
And read all of this thread.
You need 8 cells in parallel. You need as MANY CELLS as you can fit. Do not test with just 8.
You need a good hobby charger that can balance cells as it charges. You do NOT want a BMS...
