Have asked digimess if they could upgrade my PSU to 50a if it would be possible for them to do so.
There are some settings that piss me off though. Its like having big brother on your back telling you what to do. Incorrectly! It will not allow a long enough CV stage to charge my camera battery without cell balance connections for eg. I need some modifications to the lead acid charge algo too. And a few fine tuning ones to the LiFePO4 options. I don't believe that half the planet use these things but they don't know any better...
woodygb wrote:Yes.
B.M. will point out that your losing out on the benefits of a higher voltage ..but you can replace your current batteries with 24v of lithium ( LifePo4 ).
woodygb wrote:Peak voltage is your only concern .... and 8 off lithium cells has much the same peak voltage as a pair of charged 12v batteries.
steves1977uk wrote:I'm using a 24v 75Ah Lithium pack with a Pilot+ 100 amp power module with no problems.
You can't buy ready made packs, you have to measure the battery case(s) size and work out how many cells you are able to fit in the space including the cell holders.
Burgerman wrote:The VR2 doesent enter into this in any way???
Burgerman wrote:The controller has nothing to do with charging or looking after your batteries. It doesn't matter what controller you use. Apart from the fuel gauge will no longer be reliable.
Burgerman wrote:BMS is BATTERY MANAGEMENT SYSTEM. It does a lot of things. Things you may not understand. Designed to allow a dummy with no idea what they are doing, to fit a lithium battery in a place it shouldn't be, that wasn't designed for lithium with inadequate understanding. Almost every battery pack sold has one inside and they cause all the problems. In a properly integrated system, with correct cells and in the correct quantity, with a cell balancing charger you don't need one.
Burgerman wrote:That's because you still think wrong. You think lithium is a battery. Rather than a part of a system.
Users browsing this forum: DennisinTexas, duke1, emilevirus and 310 guests
