shirley_hkg wrote:My experience told me they don't.
More to say tomorrow.![]()
Burgerman wrote:As long as it is bypassed for the power take off to the chair (so the BMS has no affect). And as long as you use a charger that lets you choose 3.55v instead of something huge, and only use the BMS for cell balancing at a lower voltage then it will be fine. But the problem is that a novice as you put it will not make all these parameters correct. They will just use a generic BMS and charger and connect the powerchairs electronics to the BMS output...
What you are doing is basically taking control away from the BMS manually. Which also works of course. Provided 3.55v per cell, and at a low charge rate.
http://www.bestechpower.com/balanceboard/JH-D131A.html
I am still confused with the C-rate stuff, How AH fit into the calculation. and do multiples of cell groups increase the AH ? I would however almost always use a less than 100 amp controller, and not over 24VDC. I think i am now too old to try to progress further or need more "speed". I just want to make stuff easier for the home stretch, whatever will accomplish that.
I get the part why shirley circumvents all but the cell balancing, but I seriously doubt I would get how to do that. It would seem you would have to eliminate a part of the circuitry of the BMS. Nope
What about these gadgets and how do they relate to what we are trying to accomplish? http://www.bestechpower.com/balanceboard/JH-D131A.html
Do they have a way of connecting cell groups individually? Or each cell individually ? I seem to remember some dude finding or making BMS like units for individual cell groups. But he invalidated himself due to some of his other ideas, or so it seemed.
I have to find that AD for the cell pack I spoke of. I think I may have answered my own questions while writing this. But if you do have time please reiterate or answer those suppositions I have. Thanks guys
OK read this twice!
Take a single cell...
A 10Ah cell, rated at 10C can have 100Amps max taken from it without instant trash can.
A 10Ah cell, rated at 50C can have 500Amps etc.
In both cases they will have an extremely short lifespan.
A 20Ah cell, (or 2x 10Ah in parallel), rated at 10C can then have 200A taken from it and wont die... You just add up the cells in Ah as they are in parallel. So:
A 20Ah cell, (or 2X 10Ah or any bunch adding up to 200Ah in parallel) rated at 50C can have 10000Amps taken from it and not die. 50C is common on hobby stuff.
A 100Ah cell (or 10x 10Ah cells or whatever you use in parallel) rated at 10C can have 1000Ah taken from it and not die.
Sully wrote:Shirley; for the stupid who are still completely buffaloed by the electronics and workings of these lithiums (LiFePO4) Not any of the other lipo's thrown in at all, guys like me. Could you explain how you do your system, both words and pictures would help.
Someone on this site is going to build a 24V 180AH block
Users browsing this forum: Bing [Bot] and 208 guests
