Princess Myia wrote:These are the motors I am using plus spare ones.
Not sure if they are 2 or 4 pole motors
one 2 inch (inboard), one 2.5 inch (outboard with valve hole) and a tubeless adapter for the centre.
Noel wrote:Hi All, I'm trying to help a friend in need, he has a scooter with an S drive controller. It has a fault in that after releasing the fwd/rev lever it carries on for a short while (powered) before the electric brake comes on and power is cut to the motor. How advanced are these controllers? Could it be a fault with the plug braking or are the parameters wrong in the controller?
I'm happy to make a lead up but the setup software seems elusive if this will help?
Apologies for all the questions on my first post it's not something I work on, my day job is a senior forklift engineer, my work includes work on complex electric trucks so I have good understanding of the workings. Hence I got asked to look at the scooter.
Warmest Regards
Noel
Noel wrote:Hi woody, just making the cable up, you say you use a 47k resistor should that be 4.7k? I'm guessing the exact value isn't important.
Users browsing this forum: emilevirus, jefferso, martin007, rover220 and 400 guests
