viewtopic.php?f=2&t=4988#p66617READ all of this. Same problem...
YOU NEED HIGH POWER A123 PRESET. THEN:
And you must set ALL of these.
For which you
NEED a PC...
The PC software is about 90 percent of the charger. Realistically you need a modern PC or laptop...
You can use it without but will need to set up a mountain of settings manually with a tiny screen and you probably don't have the newest firmware installed either...
Get a PC (OR access to one!)
1. You need to choose the HIGH POWER A123 PRESET. The others are 10A limited.
2. You then need to set all of the following OR CHARGE MAY BE INCORRECT, not complete/ balanced, or cut short.
Trying to do this on the charger may not be possible or easy and some of these settings might be inaccessible or missing it looks so difficult I never even looked. So:
DETECTION
Low Voltage (L.V.) restore: 2.55V
L.V. restore time: 3 mins
L.V. restore Amps: 500mA
Parallel packs: NONE
Cells: Auto detect
CHARGE
Charge Amps: 30.00 (whatever amps you want based on your battery capacity, or power supply. The charger can do 40, most power supplies cannot.)
Increment: 5mA: NO
Charge Voltage: 3.600V (3.50 to 3.55 will take longer to charge, longer to balance but healthier for the battery. 3.65 volts is faster to balance, less good for the battery. All end up full! if time allows)
Conv Frequency: 125khz
Cold Weather T: NONE (reduces charge voltage in winter for safety, mostly for lipo batteries we don't need it)
F. Average past 1min: NO
DISCHARGE
Disch. Mode: Internal Regenerative
Discharge Profile: Constant Current
Discharge Amps: 5.00A
Discharge volts: 2.50V
CCCV Disch. : NO
Cycles: 1
End Cycle: Charge
Cool Down: 5 min
Store or discharge: NO
BALANCE
Bal Mode: PROPORTIONAL
Bal Speed: 16X
Bal Set point: -1mV
Bal entire charge: NO
Balance Disch.: NO
Balance deadband: 2mV
Balance limit CSET/10: NO
Balance Current: 1000mA
TERMINATION
Term Mode: MANUAL
Manual A setting: (70mA Larger figure like 140mA ends faster. Smaller figure like 40mA ends in a more complete charge. But depending in pack, age etc it may never end. Use whatever works best).
Require Balance Done: YES
Require all charge voltage: YES
C.V. Time out: 8 hours
SCREENS
Ignore all settings
FUEL
Pack capacity 0mAh
Use fuel table: NO
Ignore the rest...
SAFETY
Safety charge stop: NO
Charge timeout: 16 hours
Discharge timeout: 4 days
Err. Amps change: NO
Then make sure your power supply and other settings are correct. Set max Amps at or just below your supplies max. Set minimum volts to half the usual volts. Set power supply volts to your supply. Again its easy to do all this with a PC and the software.
SOME of these may be absent and only adjusted via PC... You need a PC!
Make sure you update to latest firmware 3.32 or newer - check often... Also needs a PC.
