shirley_hkg wrote:Thank you DMC-man & Irving for your replies.
Another 2 questions.
Q1, the log above is captured when motor was spinning at around 170 rpm (6.5mph @ 13.5" tyre)
If chair goes 15mph , motor will be spinning at 400 rpm. The data rate from the hall sensor will also increase.
Can you tell from the graph that HBL-2360 has enough bandwidth / processing power to do it ?![]()
As has been said, neither. These modes are generally for servo (torque) or spindle (speed) control... e.g. a CNC coil winder needs torque control to maintain a fixed tension as the bobbin fills and revs decrease... a drilling/milling spindle wants to maintain speed as the bit hits the workpiece to maintain chip load on the cutter...shirley_hkg wrote:Q2, In CLOSED LOOP SPEED MODE with brushless motors, the controller will keep motor speed to the command with variance in load. That seems to have the same effect of the CLOSED LOOP TORQUE MODE , itsn't it ?
Then, which mode should be best to drive a wheelchair ?![]()
Thanks.
Williamclark77 wrote:
The new Roboteq FBL2360 advertises compatibility with trapezoidal and sinusoidal switching as well as hall, encoder, and sensorless rotor sensing. It's a max 2x 60a output though. Will dual 60 amp output be enough for a powerchair?
stevelawiw wrote:
Does this mean that the FBL2360 would be compatible with the Invacare GB motors without any need to decode the output of the existing hall sensors?
stevelawiw wrote:Getting back to the Roboteq FBL2360, if I rework my LiFePO4 105aH 24v 7p 8s pack into 4p 14s giving 44.8v 60aH that should give me more speed, torque and greater range, right? Can't wait!
Shame there's no way of charging 17s or I could have gone for 3p 17s giving me 54.4v 45aH but only using 51 of my cells.
The controller requires the Hall sensors inside the motor to be 120 degrees apart.
shirley_hkg wrote: The student volunteer back off. No one follows, though he confirmed that the chips can do the conversions.
Users browsing this forum: Seafighter and 58 guests
