Okay, that listing doesn't really have much information, the controller looks pretty old, how can I be sure it will work for what I want to do? How do I know it's the right specs for my motors?
I'm assuming some of ya'll have used this controller in the past. The joystick is analog? So it would be relatively easy to program an Arduino to mimic the joystick signals and control the motors that way? Has anyone done this before?
jcka22 Posts: 10Joined: 16 Feb 2015, 21:00
jcka22 wrote:Hi,
I am new to this forum. I am looking to interface an Arduino board into an electric wheelchair. I found a little information on this site but couldn't find any information on actually setting this up and getting it working.
I'm not sure the brand of chair but it uses a Shark power module and control system. I know these chairs have a ton of safety features which makes it difficult to do projects like this.
Is it possible to keep the existing wheelchair circuit boards and somehow use an Arduino to control the wheelchair? Or would it be easier to just scrap all the control boards and start from scratch, keeping just the motors and batteries of the chair?
Any advice would be much appreciated !
Thanks,
Jack
jcka22 wrote:Doug, you did this with Arduino ? Or something else?
jcka22 wrote:Doug - You keep mentioning that you are bypassing your joystick. If you are doing this I am guessing yours does not use CAN communication? Since mine does wouldn't it would be nearly impossible to figure out how to communicate with the chair in this fashion?
jcka22 wrote:Okay based on what I've read it seems to be SPI. Still not sure where to begin on how to program the Arduino. Am I going to need an Oscilloscope ?
jcka22 wrote:Well that's good news that this is possible. Unfortunately I don't have a logic analyzer or an oscilloscope... It seems like even the low cost ones aren't cheap.
Would you be willing to share your Arduino code? I'll continue doing some research to see what I can find but it would be really helpful to see the structure of a working Arduino program.
LROBBINS wrote:Cracking a proprietary CAN bus, such as Dynamic uses, would be no mean task.
gcebiker wrote:This is a wixel https://www.pololu.com/product/1336, i think its basically arduino code, i smoked the first one i bought![]()
Link to Gizmosmith's blog article for those on mobile devices.
Reverse Engineering the Dynamic Controls Shark Joystick
Further Hacking of the Shark
DougL wrote:Looks great and seems like it could be a good radio setup to use. There sure looks to be enough digital I/O and analog inputs.
Users browsing this forum: Kande_ian, ricardoh, yeshelp and 83 guests
