mssmith wrote:Hi there I'm not sure if this is the right place to Post these or not so bear with me. My partner has been trying to find out about programming my Otto Bok B600 without much luck. I think he's read some of the threads here but he is so far not much further on. Getting hold of the programmer seems to be a major problem. Burgerman suggested that I post some pictures of the control box so here they are - if I can work out how to do it.Ah! I have to make my images smaller. I'll do that and try again.
Some users couldn’t be added as they have disabled private message receipt.
He has already had the tech attempt to repair with programming but failed
I may be wrong. But I doubt you will find an OEM programmer for this.
The main problem he has is while turning from a stop the chair seems to go really fast left or right with no ability to feather it. Which setting would need to be changed to correct this problem?
Burgerman wrote:The main problem he has is while turning from a stop the chair seems to go really fast left or right with no ability to feather it. Which setting would need to be changed to correct this problem?
ALL powerchairs are shipped with the following 4 crazy setting making them steer like a crazy drunken sailor.
1. Turn Acceleration
2. Turn Deceleration
3. LOW SPEED (or MIN) Turn Acceleration
4. LOW SPEED (or MIN) Turn Acceleration
All 4 need to be set to OFF which means set to 100%.
These are typically set between 15 and 35 percent, making the chair almost uncontrollable.
Otherwise you always get a delayed and ever increasing ACELERATING turn rate, and it keeps on turning long after you panic and try to stop it.... Hence wrecked door frames and inability to steer accurately. Same on every chair on the planet.
Turn RATE and LOW SPEED or MIN TURN RATES may now need to be reduced. To your taste.
SouthmanGA wrote:I'm needing to get this chair sped up, and I've read up on Quantum chairs. I've tried using a dealer programmer, but when I got to the setting(s), the +/- wouldn't allow the # to move. It is my guess it is locked?
SouthmanGA wrote: I also saw the instructions on how to build the programming interface, buy that usb and build a cable, but it's a little above my current capabilities.
Users browsing this forum: duke1, faico_26, jefferso, shirley_hkg and 554 guests
