shirley_hkg wrote: I'll keep money in my pocket, by JUST looking at :
Voltage range during discharge: 29.2V--20V
These are usually porch cells inside and that will deem to get swelling easily when overcharged.
i do want to try the whole thing one day - not sure if i can fit 108ah in my chair - its very tight and barely fits the MK 24 - no room on top or sides at all -
so it cant go higher wider longer - nothing - has to be the same or even a little less in size to fit nicely - thats one chair
the 222 se - thats another problem - the MK 24 fit in there different - one is sideways and one is straight in - so the size of the box is not the same and the case cover leans down in the rear -
that may be harder to make for that chair -
With an add-on, you are unnecessary to carry charger .![]()
Usually it is set @28.8V for gel, itsn't it ?![]()
3.6 X 8 = 28.8V ; so 29.2 is definitely OVERCHARGED , even at perfect balance.
Actually, we are charging at 28.2----28.4 with full LiFeSO4.![]()
Users browsing this forum: Superchunk and 144 guests
