Burgerman wrote:You can reprogram it so that for once in its life, it steers properly! Remove all the delay, turn acc, turn dec, and increase forward acc etc.
All chairs that are sold have abysmal programming - making them almost uncontrollable in comparison to how they can actually be. But you generally need a low level engineering or OEM programmer. Not the typical dealer version that most tech guys have. And you need to set a lot of stuff to 100, which most wont do for reasons non of us understand...
Burgerman wrote:Unless someone has turned it down to a slower speed for some reason, then it will be already set to 100% and will not go faster.
rover220 wrote:Was the one I bought a genuine ftdi?
The newest functionality to the FTDI driver released through a Windows update merely injects unwanted but predictable data into the serial stream. Having a device spit out “NON GENUINE DEVICE FOUND!” won’t necessarily break a device, but it is an undocumented feature that could cause some devices to behave oddly. Because no one really knows if they have genuine FTDI chips or not – this undocumented feature could cause problems in everything from industrial equipment to medical devices, and of course in Arduinos whose only purpose is to blink a LED.
woodygb wrote:rover220 wrote:Was the one I bought a genuine ftdi?
Has your lead ceased to function?
Users browsing this forum: No registered users and 37 guests
