ex-Gooserider wrote:With an SB-50 connector, you should be using AWG 6 wire! You can get away with AWG 8, maybe... (The 10mm^2 wire that BM uses is in between AWG 6 & 8) it is really not good to use AWG 10 on an SB-50, as it is very much undersized for the connector's capacity.
I have purchased wire and other things from GenuineDealz, and the stuff I've gotten has been good. I haven't had them make any cables for me though so I don't know how that service is...
However you don't want to even think about soldering heavy gage cables without the right gear and a lot of experience. (and the Deans connectors I've used are really NASTY things to try and solder!)
In general, I would suggest that until you have a MUCH better understanding of how all the pieces fit together than you have shown so far, you shouldn't attempt this kind of project - it is easy and safe ONLY if you understand what you are doing and why - without that understanding I could easily see you causing your self major damage and possibly even injury....
Burgerman wrote:As BMS systems go this is better than most but still intended to allow diy conversions by those that don't realise you don't need one! It only does 12S anyway I think. Most real EVs are using high voltages and probably 5x this. My battery is already too many at 13S..nealnlx wrote:Lets see..
What a charger does is to apply power to each end of a cell or a battery untill it overlows. They go to the fullest and dont stop making the cell voltage goes mad like you said.
Its like filling a bucket with sand untill it passes the top.
And what a BMS does is analyzing it ONLY AFTER it already passed the top and then when sees the overflow the BMS unplugges the thick charger cables and connect his litle board ones and kind of slowly sweeps the exccess of sand out untill its all leveled with the bucket.
It does this to all the buckets/cells several times until they are all at the same lever/voltage.
The result is that with this the cell are not only going through the roof getting damaged in the first tick cables charge because they pass the expectable safe voltage and also get into a kind of cycling methog that the BMS does when discharging and recharging again taking of life cycles that should be used by us.
Am i right untill now or all wrong?
What you hobby charger does is, because it is pre-programmed to charge a cell only untill certain limits, it does not exceed it.
When I'm using 40Ah add-on with 73Ah MK Gel , the wire is 1.5mm with XLR plug. Current is around 10A, occationally near 20A.![]()
Don't bother too much on wire size and heavy duty connectors.
Burgerman wrote:Hobby charger is the best at the moment. But things change fast in the hobby industry.
It can charge any battery, fron something like a watch battery, to a full sized Eelectric Car. And any chemistry. And any voltage or cell count up to 24V and 8 cell lithium, 12cell Lead etc. Or 10 cell unbalanced LiFePO4. And more cells on nicad, nickel metal, and more.
Its very configurable, and you must get the USB connetor too. So you can set it up and control it, as well as monitor whats happening on a PC.
Your mobility charger can charge at 24V and at 8 Amps usually. Thats about 200 watts. This charger can charge at 50mA which is nothing, up to 1340 watts...
It needs to run from a 12 or 24 volt (up to 32v) power supply. To get absolute max power from it you need 27Volts. I have one in my van, and can charge from an anderson connector on the dashboard, via the charger if I want. Although only at about 2/3rds power. Which is plenty.
I also have a couple of these chargers in the house. These run from a power supply. To use full power you need a big powerful 24 to 28 volt supply. I use two of these: http://www.ebay.co.uk/sch/digimess/m.ht ... 7675.l2562
Ok now this is what i wanted to avoid - the extra PSU - the cost is high - when i add this all up - is there a less expensive option or combonation to get this done correctly - i have no idea what to even do with that PSU in the link
i though i just needed to plug it in the wall and plug the hobby charger in the PSU and thats it -
this is going to run about $600 maybe and thats with out the 8 Cells - i know you know its the best to use etc, - but is there another option to get the job done for less - ?
But the SM3040 MODEL. 30V 40A. But there are none today. This seller usually has a couple a month, as new for 200 pounds. But there are many power supplues available.
are these the same batteries chemistry as the ones we use here ?
i may just get 10 to be safe in case i need an extra one -
Users browsing this forum: Bing [Bot] and 371 guests
