Burgerman wrote:Theres a 101 ways to do things.
Can you get cables soldered up?
If so its best to swap main battery connectors for something else. If not you can buy 4x adapters...
Then after that you will be using the T connectors, or something else. It all depends.
How many batteries?
shirley_hkg wrote:17% per every 10AH.
Burgerman wrote:Anything will work.
You want as many wires, and as much complication / connections as that to DIY? And the most unreliable, and actually a fundamentally wrong way to do it, after all?![]()
I give up!
shirley_hkg wrote:BM, doing add-on your way will make charging inconvenient. Two batteries have to be charge seperately.
You know that, don't you ?
expresso, all 3 cells are selling @ $1.6 per AH . I recommand to you the big brother 40152s if space allow.
Burgerman wrote:Yes. And no. The hobby charger can charge both just like the dumb mobility charger. And do a better more controllable job of both. But its not the best way.
Although doing them at the same time should work exactly the same as using a BMS/dumb mobility charger at the same time, only with better control of termination current level, (you tell it 50mA etc) and much more precise termination voltage (you get to decide).
However. The best way is to charge the add on separately in any case, since the best termination voltage and current is not the same for both types of cell. The Hobbyking cells for eg can be charged at 40A with a hobby charger, and will only take a few mins (25 mins from a typical 80%DOD?) as they can be charged fast! So you can do those read for when needed as you eat dinner... Then put them in your pocket for later. No extra wires, no BMS, all pre wired, just plug and play.
http://www.hobbyking.co.uk/hobbyking/st ... ouse_.html
30C cells, and charge at 2C. So 30 to 40 mins to 100% full from 100% discharged with a 1A balance 40A charge PL8v2 charger... And small enough for your pocket! Just 6" x 2" x 2.5" in physical size. But you need 4 for 24V and 16.8Ah. And these are 30C, much better than typical 3 or 1C prismatics/headway etc.
But the lead battery NEEDS an 8 hour soak at CV AFTER charge to not end up sulfated. Doing both together isn't ideal for either Lithium doesent like long soaks at full voltage. Obviously it will work. But I wouldn't do it that way.
I like the size part - but i do need 4 - double the cost for the batteries alone - - and then add in the cost of the charger - PSU - besides the fact that i never done this - wouldnt this be harder for me - connetions - wiring them together etc, - would i have to solder ? i want to do it - either way that would be best for me and my ability - or should i say knowledge on this -
Scollard wrote:expresso,
Here is a cheap power supply on eBay.
http://r.ebay.com/6Qb3ph
It's essentially 2 computer server power supplies wired in series. This is what I use to power my Hyperion 1420i.
BM,
I just got my FedEx notification for my Lithiums from Hong Kong. I will be building my pack very soon. I will try and do a step-by-step on the forum.
I'm building a pack to replace 2 group 27 lead batteries. It's going to be a 7p8s pack made with 15AH Headway cells.This will yield a 24V 105AH pack.
i feel its too tight on top of my pack - i dont want to squeeze it in there - the specs show 235mm - high for my battery -
lets assume for a moment - with just the specs i posted - can a pack be done - even if its not a group 24 replacement pack - lets say i can only get a group 34 pack to fit - that would still be a huge improvement i think ?
BM wrote:One thing worries me a little. You are throwing away much of the advantage that lithium offers. That is that its more energy dense, so you should be able to fit 1.4 to 2x the Ah in the same volume/space.
Burgerman wrote:i feel its too tight on top of my pack - i dont want to squeeze it in there - the specs show 235mm - high for my battery -
The spec for a group24 is 260 long. 174 wide. 240 high. They can be less, they cannot be more. If your chair is designed for grp 24 batteries that will fit.
Which means your 235 figure is allowing 5mm (3/16ths inch) clearance for the metal terminals. The lithium pack doesn't need that...
If the battery can be 240 high (9.4 inches) then its 6 cells tall.
If the battery can be 260mm long (10 inches) then it can be 6 cells long. That's 36 cells. Times 2 for 2 batteries... That's 72 cells. That's 108Ah and a long service life with about 2.5 to 3 times more range.
If its 13 inches long as you said, that's another 3 inches per battery. That's another 6 cells per pack possible. But just another 4 makes more sense so another 12Ah added and 120Ah. That's 3.5 to 4x the range.
48 cells means just 72Ah. Same as the lead you take out. Kind of misses the point whole point of lithium. Which is that you can fit more ah in a given space. It will mean daily charging instead of every few days, so shorter life and only about 1.6 times as much range.
Users browsing this forum: acid_coke, Bing [Bot], emilevirus, shirley_hkg, Superchunk and 116 guests
