Where to find PGDT programmer software
Re: Where to find PGDT programmer software
Postby woodygb » 20 May 2015, 10:11
Check your message inbox.
Postby DougL » 16 Jun 2015, 16:39
I just received the Yamaha programmer cable and also having a tough time finding the programming software for the Pride Mobility GC2 and VR2 controllers.
DougL
Postby mp3-king » 20 Sep 2015, 14:11
Hi, i am from Germany (sorry for my english)
I have a Scooter with a PG Solo and sarch a Programming Software to change the settings.
I hope everyone can help me...
your mp3-king
mp3-king
Postby woodygb » 20 Sep 2015, 14:50
The Mobility software will "talk" to the SOLO...but WILL NOT PROGRAM the SOLO controller....
solo comms.jpg (92.44 KiB) Viewed 15583 times
You need a handheld programmer SP1 OEM version or the Industrial software.Image
Postby mp3-king » 20 Sep 2015, 15:22
Where I can find the Industrial software?
mp3-king
Postby steves1977uk » 20 Sep 2015, 16:35
Thats the £64,000 question :mrgreen:
I imagine the industrial pc programming software is almost impossible to get as it's hard enough trying to buy the mobility version.
Postby mp3-king » 21 Sep 2015, 15:47
Thank you for your quick response
mp3-king
mp3-king
Postby markusb » 10 Dec 2015, 07:59
Hi guys,
I have a chairman with a pilot + system that Im trying to use for a project.
I was trying to find the programming software for the power module but bandwidth exceeded it said. Is there any updated link to the software?
I dont know if this is the right board for this other question, but I'll ask away :)
The chair is fully functioning except it does not move! Brakes does not release, wheels do not turn.
Seat actuators, lights and so on works. I get no error flash on the bar graph display, but if I disconnect a brake or a motor it registers a fault and makes a flashing pattern.. It just does not move when pulling the stick.
Is there more inhibits than the cable from the manual brake release? Or what can cause this problem for me?
Thanks in advance!
markusb
Postby Burgerman » 10 Dec 2015, 13:23
There can be more inhibits, or reversed ones. All can be cancelled in programming.
Check PM
Postby rlnguy » 10 Dec 2015, 22:35
I am assuming by chairman, you mean Permobil Chairman?
On Permobil Chairman, the most common reason for a drive inhibit is the connection to the freewheel lever switch. Just in front of the right motor (as sitting in the chair), there is a small black connector. If you follow the wires back from the switch, it's easy to find. It is very easy to pull the wires just enough, when putting new batteries in, for example, to unplug this connector. I've had that call, probably a hundred times.
You have to remove a few covers to access it, but that's where I would start.
depending on configuration, it could also be inhibited because the seat is raised (or thinks it is). There could be other possible, as well.
hope this helps
rlnguy
Postby markusb » 11 Dec 2015, 07:28
I found the problem.. The two control boxes for the actuators was mixed with the boxes from another chair. I swapped them, and checked all inhibits I could find in the schematic.
Now it runs fine!
markusb
Postby lakonas » 02 Feb 2016, 23:08
Hi guys,
I'm looking for the mobility scooter programming software for the S-Drive (D51446.06).
Thanks in advance!
lakonas
Postby phoenix » 20 Jun 2016, 17:23
Hello,
I'm also looking for the OEM PC Programmer for the S-Drive controllers. Can someone help?
phoenix
Postby woodygb » 20 Jun 2016, 17:30
It may appear in your Inbox.
Postby Ben » 28 Jun 2016, 04:00
I am looking for the programming software for pgdt s drive controller.
Can someone help ?
Ben
Postby Burgerman » 29 Jun 2016, 01:34
Does the usual mobility programmer not include this? it may help to pm woodygb if not.
Postby Ben » 29 Jun 2016, 11:30
Thanks Burgerman and Woodygb,
I found it and I will proceed with the assembly of my own programming cable now !
Ben
Postby phoenix » 08 Jul 2016, 23:58
Can someone help me get a recent manufacturing version (Level C) of the software? I'm looking for version 14 or later.
I do have an older version but it doesn't read some controllers.
phoenix
Postby baravantan » 09 Jul 2016, 06:45
I'm looking for the OEM version of the PC Programmer for the EGIS/SDrive controllers. Can someone help me?
baravantan
Postby Ben » 14 Jul 2016, 18:26
Thanks again Burgerman and Woodygb,
I build a cable wkth a FTDI USB and It work...
:mrgreen:
Ben
Postby PaulieTheKid » 22 Jul 2016, 13:31
I'm looking for the PC mobility programmer programming software for the Penny & Giles model EGIS 110 controller.
Does anybody know where to find it, or can somebody hook me up?
Thanks,
Paul
PaulieTheKid
Postby c500user » 23 Jul 2016, 19:24
I do not know if this is of help to anyone, but I came across a download link at the US Permobil site. The R-Net software seems to install fine on my Win7 PC, but I have no dongle so cannot connect to my C500.
http://www.permobilus.com/software.php
Permobil C500 main
Permobil C500 spare
c500user
Postby rover220 » 23 Jul 2016, 20:08
c500user wrote:I do not know if this is of help to anyone, but I came across a download link at the US Permobil site. The R-Net software seems to install fine on my Win7 PC, but I have no dongle so cannot connect to my C500.
Only dealer level unfortunately.
Postby c500user » 23 Jul 2016, 20:31
How easy is it to get hold of a dongle? I would not mind starting with a dealer version to see if I can get the chair to behave itself.
Permobil C500 main
Permobil C500 spare
c500user
Postby Burgerman » 23 Jul 2016, 20:42
OEM software is easy...
Dongle isnt! Well at least an OEM one isnt easy to get.
Postby c500user » 23 Jul 2016, 20:48
But how hard is it to get a dealer dongle?
Permobil C500 main
Permobil C500 spare
c500user
Postby Burgerman » 23 Jul 2016, 20:50
Anyone can buy one. Dealer = end user, same thing. You can even find someone WITH an OEM version and let him reprogram your R-net to have DEALER level On Board Programming built in. Or rather enabled. Since its already in there!
Postby c500user » 23 Jul 2016, 20:59
Then I need to find someone to do that for me in Holland!
Permobil C500 main
Permobil C500 spare
c500user
Postby Burgerman » 23 Jul 2016, 21:38
Postby somsak » 02 Sep 2016, 16:49
Hi all,
My wheelchair is breakdown. When I push joystick forward left side reverse and right side is forward. when pull joystick back left side forward and right side reverse. I suspect VR2 controller got a problem. Where I can get a pc programmer software. Realy need help. Thanks
somsak
Users browsing this forum: acid_coke, DennisinTexas and 365 guests
