expresso wrote:Ok - thanks - looks nice - simple enough once i know where to put those balance leads![]()
Shirley - you added an XLR also to charge with slower charger ? also the Pos and Neg. cables - those have ring terminals also ? i am still waiting on my other 8 Cells - not sure what happened but they are still in HK
Regarding your initial balancing, I'll include a DC-DC power module to bring up lagging behind cells to 3.6V.
One by one , though a bit slow.![]()
Your money has paid for it.![]()
once done - i can charge once a month during the winter if i am not connecting it to the chair ?
Burgerman wrote:Again, the PL8 can charge full, balance, in 20mins then discharge to say 60 percent for storage. Or can charge to say 3.38V per cell and balance. But its less important anyway, because it balances literally 10x the speed. So no real need, it will just rebalance in summer fix it fast as you charge.
shirley_hkg wrote: Whenever connecting 2 cells or 2 batteries together in parallel, you MUST check and ensure their voltages are nearly the same.
That takes some work.
I shall leave them connected and would not seperate them with no reason.
Scollard wrote:Burgerman wrote:Again, the PL8 can charge full, balance, in 20mins then discharge to say 60 percent for storage. Or can charge to say 3.38V per cell and balance. But its less important anyway, because it balances literally 10x the speed. So no real need, it will just rebalance in summer fix it fast as you charge.
I'm with BM. A BMS needlessly complicates matters, is a point of failure, and is way slower than a hobby charger. With a PL8, or Hyperion in my case, and a combo Sub-D connector you have the simplest most powerful system. I'm building my LiFePO4 pack with that in mind. I have all my individual cells charge saturated and they are sitting for 1 month. Then I will determine each cells self discharge rate and build my 8 parallel cells so they self discharge as close to the same rate as each other. Then my Hyperion keeps everything in check.
Expresso, an answer to one other question you had: I did get an invoice from FedEx for Duty. It was only $20 so I just paid it rather than try and figure out how to import them tax free.
I'm still trying to figure out a slick way to monitor the usage.
expresso wrote:looking over some of the other chargers - the 20 amp i have floats at 27v and also the salmex so those both would be good also - and faster to charge - the slower charger at 5 amp also does 27 V float - and the 8 amp i think does 27.6 or 27.7V float - at 28.8V charge thats the generic one you get with the chair -
I have to visit a hospital twice a week which is a 25 mile round trip.
Users browsing this forum: No registered users and 407 guests
