Burgerman wrote:Wrong.
My chairs are just 37 inches long total inc footplates, (shorter than all other powerchairs). And both of your rear drive chairs are as long as an oil tanker and they have the rear wheels behind your backside. Mine are UNDER it so it turns under you.
http://www.wheelchairdriver.com/images- ... ir-700.jpg
If I reverse to a wall, my HEAD touches first.
My toes are 37 inches from my head. Thats about 10 inches shorter than your chairs or any mid drive chairs.
Footplate is central so no swingaway footplate to hit doorframes, and anti tips are inboard and short for same reasons.
Anyplace you can get with a centre drive I can go too... And turn around.
So rear drive CAN work indoors if configured well.
http://www.wheelchairdriver.com/gopro/control.mp4 And are better for control!
Burgerman wrote:My chairs are easay to drive at a super slow slugs pace.
I do not need a profile set up for "slow" indoor. Once CORRECTLY programmed, they go and steer exactly as fast as you "think" them to go.
No longer is there any need for setting a slow profile, any more than setting your computer mouse to slow to click an icon...
Even this:
http://www.wheelchairdriver.com/BM3-con ... /15mph.mp4
ex-Gooserider wrote:I can sort of see Jonv's point... Even with good hand control and the rest, if I'm travelling with someone and I want to go the same speed they are, it is easier to dial back the top speed with the pot and nail the joystick than it is to hold it half way... Not so much physically demanding to hold it, as that it takes less concentration, so I can pay more attention to the people I'm with...
jonv wrote:Aex-Gooserider wrote:I can sort of see Jonv's point... Even with good hand control and the rest, if I'm travelling with someone and I want to go the same speed they are, it is easier to dial back the top speed with the pot and nail the joystick than it is to hold it half way... Not so much physically demanding to hold it, as that it takes less concentration, so I can pay more attention to the people I'm with...
Could a manufacturer install a pot ?
I was hoping I could sort of palm the joystick as my thumbs are pretty bad.
Burgerman wrote:Many manufacturers have systems with a pot (speed knob) already.
But theres no way on earth to have proper control of a properly programmed chair with the palm of your hand. That MUST sit alongside the joystick pod as a stability aid and position reference. Its unlikely you woul;d be able to use the same settings I use. You would benefit from removing all the delays in acc, and decelerating a turn. But would need all the turn rates and forward acc rates lowered so it can be operated with less "finess" so to speak.
Depends. Take a look at the label on the charger. Many these days can handle 110 as well as 220, either automatically or via a switch. Ciao, LennyBTW if I go to US as im planning too , I assume I will need a 240 - 110v transformer ?
LROBBINS wrote:Depends. Take a look at the label on the charger. Many these days can handle 110 as well as 220, either automatically or via a switch. Ciao, LennyBTW if I go to US as im planning too , I assume I will need a 240 - 110v transformer ?
Users browsing this forum: Burgerman, emilevirus and 81 guests
