Burgerman wrote:No. Starts at 4.2V and drops as you see here. When flying my quadcopter I make sure its down by 3.7V per cell. After that it drops off a cliff. And there's almost zero drop under load. They don't last either. Used hard in planes etc 60 to 90 cycles and they go in the bin. But cheap and exciting! Boom...
Scollard wrote:I have the two batteries all hooked together with the balance wires all attached.
I got the charger-side cable done today. Charge mains are not hooked up yet, I will do that when I actually install the batteries. In the meantime I'm using the Anderson to charge and the balance wires are all running through the Combo Sub-D. Just taking a look at the cells now on the Hyperion.
I have the time, no problem discharging to 2.6 V/cell then?
Users browsing this forum: Bing [Bot], shirley_hkg and 184 guests
