Postby shirley_hkg » 23 Feb 2016, 05:44
Burgerman wrote:steves1977uk, you are supposed to have all the parallel ones linked with a bar. And only need each series sets linked with one bar. As it is, any difference in cell resistance will mean a different voltage per cell under load, and those thin balance wires will be trying to balance a x amp load... That's probably why it never looks very balanced as you charge.
BM, you are really paying attention.
That is not a proper setup.
You should do parallel connection first, then in series.
Postby Scollard » 23 Feb 2016, 07:34
This is a classic case of not ordering enough busbars and just trying to make due. That tiny red wire is the parallel connection and is much too small to be used in that way. The balance wire is actually a much larger wire that you can see on the top row of cells.
Scollard
Postby Burgerman » 23 Feb 2016, 10:01
All the horizontal ones need to be vertical. Only 3 need to be horizontal in that picture to give the series connections.
It needs more bus bars too.
Postby steves1977uk » 23 Feb 2016, 11:50
Yes, that would explain why it takes a while to balance. As I understand it from what shirley said, it needs to be parallel first and then series? I do have more 2-hole buss bars, but was unsure where they'd go. I should be getting this pack rewired with thicker balancing wires, as I believe the engineer only used the wires from the OBD cable that I use for the balancing plug.
Scollard, can you show both sides of your built pack please? Then I can show the engineer how it's supposed to be built.
Thanks,
Postby steves1977uk » 23 Feb 2016, 12:01
expresso wrote:Steve - you had a fuse on both pos and neg wire ? what amp fuse did you use - why both wires ? why add a fuse if the chair has a fuse also - ?
besides the fuse on the charge cables -
I used a 150 amp fuse as this chair never had one when it was used with lead batteries. The only sort of fuse it had was a 2 pin plug that is moulded in bakelite material, and that was prone to keep falling out unless the pins were bent inwards slightly to give a tighter fit.
Postby Burgerman » 23 Feb 2016, 12:41
It should be connected the same as both end parallel blocks are.
So you have rows of vertical bus bars. Then you just need one horizontal one in the middle, that goes where you have 5 now...
Then you can get rid of all of the thin red interconnecting wires.
To save time, you could just add a connector in every place you now have a thin red wire now instead. Both top and bottom.
Postby shirley_hkg » 23 Feb 2016, 14:57
Steve , ring terminals may have better quality than those connectors.
All it need is a thicker wire ; 12AWG /1.5mm square etc. ;)
646-SE has a 100A CIRCUIT BREAKER . Too large a fuse means no protection. :cry:
Postby Burgerman » 23 Feb 2016, 15:27
Shirley, the charger and balance circuits he is using will see and try to balance a 0.001mV difference, and slow down charge etc to be sure it does this. Thin cables like 1.5mm2 are inadeqate to hold all cells in a parallel block to exactly this small margin. You need the bus bars, or some thicker cables than that. Or under charge or discharge the variable cell impedance will drag the voltrages on individual cells around.
So a 1.5mm2 cable might be OK on a low accuracy BMS but is not inadequate on a decent charger. It also means that if say 1 cell fails or goes very high resistance, those small wires will see a huge Amp load when you charge or drive the chair and melt.
Postby expresso » 23 Feb 2016, 19:57
@ BM - Ok here is the First Charge with your 150ah preset
i am curious - i took a snapshot when done - says 100%
i left it connected - its still connected now - but short while it says 99% done - you see it on the second snapshot -
and now i am watching it - goin to 98% done back and forth to 99% -
is this Correct ? i am about to remove them and start another 10 Cells
Postby Burgerman » 23 Feb 2016, 20:03
As I said, many times, you cannot tell state of charge by voltage. Ignore it.
I said to alter the 1S preset for charging 1S sets of cells!
Presumably this is 10 in parallel? You must read and give details.
Those are full, and a fraction under 2Ah added.
Do the next set.
EDIT This IS the 1S preset... You said it was the 150-Ah preset. But it says LiFe on it... So this is the correct preset. Dont mix them up!
Postby expresso » 23 Feb 2016, 20:48
yes thanks - its life - 1s 150ah first charge preset -
just started next 10 Cells - i love the software on computer to watch etc - with out you dont know whats going on -
Postby Scollard » 23 Feb 2016, 21:05
expresso wrote:yes thanks - its life - 1s 150ah first charge preset -
Yes, just what we've been telling you all along.
Scollard
Postby Scollard » 23 Feb 2016, 21:06
Thanks,
Front:
Back:
Scollard
Postby expresso » 23 Feb 2016, 21:18
When i added the presest you made -
the first preset i put for charging ONE Cell only
2nd preset is for the ADD ON
3rd. preset is for the Whole pack when done - will be either 90ah or 105ah - will shoot for 105ah
4th preset is for 10 Cells in a Roll - 105ah - first charge - 10P 1S
Postby Scollard » 23 Feb 2016, 21:22
expresso wrote:When i added the presest you made -
You mean 150Ah for the 4th preset. And it had a 200mA termination current, Correct?
Scollard
Postby Burgerman » 23 Feb 2016, 21:30
I didnt remember doing a 4th! :D :roll:
Yes. It was afterwards wasnt it?
Yes that will do it.
Postby steves1977uk » 23 Feb 2016, 22:36
Scollard wrote:
Thanks,
Front:
Back:
Thanks for that Scollard, most helpful :)
Postby expresso » 24 Feb 2016, 00:35
Yes - i have 4 presets made by BM - one of them is for the 150ah and 200mA Termination - i am using this preset to charge up 10 at a time - at the end - tomorrow morning i will finish it up -
the last 8 Cells - i will use the same preset but change the current from 200mA to 160mA - i would be done after that - store for 6 weeks -
i am liking this so far - :)
Postby expresso » 24 Feb 2016, 00:40
Burgerman wrote:I didnt remember doing a 4th! :D :roll:
Thanks Again for the presets - so far so good - and yes you made me 4 of them - i dont remember in what order i added them to the PL8 - but i have 4 all together -
i think tomorrow is my last delivery for all the parts i will need - etc, to finish up the whole job - my Cart is so full - i have to organize that also -
the only graphs i am able to see and save etc, is the one posted before - is that all there is - or does it have others besides just the line graph ?
Postby Burgerman » 24 Feb 2016, 01:06
You can save and export all the data and the graphs, as a data file. And reopen it again with the same software.
Or export that to all to excell as a numerical file with mountains of data.
Or save just an image of the cell voltage/time, pack voltage/time, charge Amps/time, resistance/time, power supply voltage off load and on load voltage/time, capacity returned/time, And the last 2 fuel or Fallback over time are for Cadmium based packs.
And the same with discharge...
You can also import and export and save presets, and also the options and options settings.
You can also export or save all your preset settings at once, or import them. Or do so individually. And there are more presets in the folder that has the extra folders full of presets... I will leave you to find that!
Postby steves1977uk » 24 Feb 2016, 01:23
The PL8 is an excellent piece of kit, just a pity it wasn't so restrictive! I also have a Hyperion 1420i which I've never used, keeping that as a backup.
Postby expresso » 24 Feb 2016, 01:26
So much - the only way i figured out so far is the pictures i posted of the graph etc, - thats it -
lets say i start a charge - i go to view and save graph etc, - thats it - but how do i get all the details besides just the line graph i got today
Postby expresso » 24 Feb 2016, 01:29
steves1977uk wrote:The PL8 is an excellent piece of kit, just a pity it wasn't so restrictive! I also have a Hyperion 1420i which I've never used, keeping that as a backup.
yes so far i love the PL 8 - i like using it on the computer to view etc, - if i had to use the charger for everything - and not have a pc hookup - i may not like it as much -
glad thats not the case and i can do everything on the computer to control it -
Postby steves1977uk » 24 Feb 2016, 01:34
Did you save the data at the end of the charge expresso? You can re-open the saved ones anytime when you're not charging and view all the details of your previous ones and compare :)
Postby expresso » 24 Feb 2016, 02:32
dont think so - thats what i have to figure out how to save the data - i saved the graph thinking that was it -
dont think i have any data saved so far - will try it tomorrow to save data thats what i wanted to do - save data - graph etc
Postby steves1977uk » 24 Feb 2016, 17:42
expresso, when you view the graph, if you click on view in the menu bar, you'll see Amps vs Time, Cell Volts vs Time, etc... This will give you more info about your cells.
Postby expresso » 24 Feb 2016, 17:51
Yes i see that Steve - but i really dont see data like numbers etc, - maybe you dont when you charge just one large Cell - 1S pack ?
Postby steves1977uk » 24 Feb 2016, 18:06
you should see something like this when you export the graph data to a text file... An example...
Code: Select all
DateTime   SlaveNum   Cycle   Mode   SupplyVolts   LSupplyVolts   SupplyAmps   PWM   SecTimer   AvgCellVolts   MaxCellVolts   AvgIR   FallBackVolts   CVStarted   SlowAmps   AvgAmps   FastAmps   SetAmps   AhrIN   AhrOUT   PackVolts   AvgPackVolts   Fuel1   SumError   Cell1Volts   Cell2Volts   Cell3Volts   Cell4Volts   Cell5Volts   Cell6Volts   Cell7Volts   Cell8Volts   Cell9Volts   Cell10Volts   Cell11Volts   Cell12Volts   Cell13Volts   Cell14Volts   Cell15Volts   Cell16Volts   Cell1IR   Cell2IR   Cell3IR   Cell4IR   Cell5IR   Cell6IR   Cell7IR   Cell8IR   Cell9IR   Cell10IR   Cell11IR   Cell12IR   Cell13IR   Cell14IR   Cell15IR   Cell16IR   BP1PWM   BP2PWM   BP3PWM   BP4PWM   BP5PWM   BP6PWM   BP7PWM   BP8PWM   BP9PWM   BP10PWM   BP11PWM   BP12PWM   BP13PWM   BP14PWM   BP15PWM   BP16PWM   Debug1   Debug2   Debug3
24/02/2016 13:08:58   0   0   6   24.53   24.68   0   8798   10   3.313   3.3171   0   0   False   0   0   -0.01166667   15   0   0   26.502   26.502   28   0.023   3.313   3.313   3.313   3.313   3.313   3.313   3.313   3.313   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
24/02/2016 13:09:00   0   0   6   24.53   24.68   0   8798   10   3.313   3.3171   0   0   False   0   0   -0.01166667   15   0   0   26.502   26.502   28   0.023   3.313   3.313   3.313   3.313   3.313   3.313   3.313   3.313   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
24/02/2016 13:09:10   0   0   6   24.54   24.68   0   8778   21   3.313   3.3171   0   0   False   0   0   -0.01833333   15   0   0   26.502   26.502   28   0.011   3.313   3.313   3.313   3.313   3.313   3.313   3.313   3.313   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
24/02/2016 13:09:20   0   0   6   24.53   24.68   0   8776   30   3.313   3.3183   0   0   False   0   0   0   15   0   0   26.502   26.502   28   0.011   3.313   3.313   3.313   3.313   3.313   3.313   3.313   3.313   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
24/02/2016 13:09:30   0   0   6   24.67   24.43   18.8   9136   40   3.331   3.3346   0   0   False   11.10167   11.33   15.92667   15   0.0065   0   26.651   26.651   28.6   0.023   3.331   3.331   3.331   3.331   3.331   3.331   3.331   3.331   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0
24/02/2016 13:09:40   0   0   6   24.67   24.45   17.6   9160   50   3.35   3.3533   0   0   False   13.045   13.26   14.91333   15   0.0484   0   26.8   26.8   48.5   0.023   3.35   3.35   3.35   3.35   3.35   3.35   3.35   3.35   0   0   0   0   0   0   0   0   0.7   0.8   0.8   0.7   0.8   0.8   0.8   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   64   296   0
24/02/2016 13:09:50   0   0   6   24.67   24.45   17.7   9186   60   3.362   3.3658   0.8   0   False   13.76167   14.11833   14.89833   15   0.09   0   26.903   26.903   59   0.023   3.362   3.362   3.362   3.362   3.362   3.362   3.362   3.362   0   0   0   0   0   0   0   0   0.8   0.7   0.8   0.7   0.7   0.8   0.8   0.9   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   296   0
24/02/2016 13:10:00   0   0   6   24.67   24.44   18   9202   70   3.37   3.3733   0.8   0   False   14.45   14.53167   14.875   15   0.1314   0   26.972   26.972   65.3   0.011   3.37   3.37   3.37   3.37   3.37   3.37   3.37   3.37   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.8   0.9   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   296   0
24/02/2016 13:10:10   0   0   6   24.67   24.44   18   9216   80   3.375   3.3796   0.8   0   False   14.53833   14.73333   15.07667   15   0.1731   0   27.018   27.018   69.2   0.023   3.375   3.375   3.375   3.375   3.375   3.375   3.375   3.375   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.8   0.9   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   296   0
24/02/2016 13:10:20   0   0   6   24.66   24.45   17.7   9222   90   3.38   3.3833   0.8   0   False   14.65833   14.85333   14.82667   15   0.2148   0   27.052   27.052   72.2   0.011   3.38   3.38   3.38   3.38   3.38   3.38   3.38   3.38   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   0.9   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   296   0
24/02/2016 13:10:30   0   0   6   24.67   24.44   17.8   9232   100   3.382   3.3858   0.8   0   False   14.76667   14.92   15.08167   15   0.2565   0   27.075   27.066   75.5   0.011   3.382   3.382   3.382   3.382   3.382   3.382   3.382   3.382   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   0.9   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   295   0
24/02/2016 13:10:40   0   0   6   24.67   24.44   18.1   9234   110   3.384   3.3883   0.8   0   False   14.84167   14.95833   14.87167   15   0.2981   0   27.087   27.082   75.5   0.011   3.384   3.384   3.384   3.384   3.384   3.384   3.384   3.384   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   295   0
24/02/2016 13:10:50   0   0   6   24.67   24.44   18.1   9238   120   3.386   3.3908   0.8   0   False   14.895   14.97667   15.11833   15   0.3397   0   27.098   27.098   78.8   0.023   3.386   3.386   3.386   3.386   3.386   3.386   3.386   3.386   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   294   0
24/02/2016 13:11:00   0   0   6   24.67   24.44   18   9242   130   3.387   3.3921   0.8   0   False   14.93   14.98833   14.98   15   0.3815   0   27.11   27.11   80.6   0.011   3.387   3.387   3.387   3.387   3.387   3.387   3.387   3.387   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   294   0
24/02/2016 13:11:10   0   0   6   24.67   24.44   18.1   9242   139   3.388   3.393   0.8   0   False   14.95   14.99   14.74333   15   0.4188   0   27.121   27.119   81.3   0.011   3.388   3.388   3.388   3.388   3.388   3.388   3.388   3.388   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   294   0
24/02/2016 13:11:20   0   0   6   24.67   24.44   18.2   9246   149   3.389   3.3935   0.8   0   False   14.96667   14.98333   14.96833   15   0.4603   0   27.132   27.122   82   0.023   3.389   3.389   3.389   3.389   3.389   3.389   3.389   3.389   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   293   0
24/02/2016 13:11:30   0   0   6   24.67   24.44   18.2   9246   159   3.39   3.3946   0.8   0   False   14.98167   14.99167   15.07667   15   0.5019   0   27.132   27.132   82   0.011   3.39   3.39   3.39   3.39   3.39   3.39   3.39   3.39   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.7   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   71   292   0
24/02/2016 13:11:40   0   0   6   24.67   24.44   17.9   9248   169   3.39   3.3946   0.8   0   False   14.99167   14.99   14.85667   15   0.5437   0   27.132   27.135   82   0.011   3.39   3.39   3.39   3.39   3.39   3.39   3.39   3.39   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.7   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   71   292   0
24/02/2016 13:11:50   0   0   6   24.67   24.44   17.8   9246   179   3.391   3.3947   0.8   0   False   14.98   14.98167   14.79167   15   0.5854   0   27.144   27.142   82.6   0.011   3.391   3.391   3.391   3.391   3.391   3.391   3.391   3.391   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:12:00   0   0   6   24.67   24.44   17.9   9252   189   3.391   3.3958   0.8   0   False   14.97167   14.97833   15.17333   15   0.627   0   27.144   27.144   83.3   0.011   3.391   3.391   3.391   3.391   3.391   3.391   3.391   3.391   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   293   0
24/02/2016 13:12:10   0   0   6   24.67   24.44   17.9   9252   199   3.392   3.3958   0.8   0   False   14.98833   14.99667   15.07667   15   0.6685   0   27.144   27.144   83.3   0.011   3.392   3.392   3.392   3.392   3.392   3.392   3.392   3.392   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   293   0
24/02/2016 13:12:20   0   0   6   24.67   24.45   17.9   9252   209   3.392   3.3958   0.8   0   False   15.005   15   14.85667   15   0.71   0   27.144   27.144   83.3   0.011   3.392   3.392   3.392   3.392   3.392   3.392   3.392   3.392   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   293   0
24/02/2016 13:12:30   0   0   6   24.67   24.44   18.1   9250   219   3.392   3.3963   0.8   0   False   15   14.99667   15.06167   15   0.7516   0   27.144   27.147   82.6   0.011   3.392   3.392   3.392   3.392   3.392   3.392   3.392   3.392   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:12:40   0   0   6   24.67   24.45   17.9   9250   229   3.392   3.3971   0.8   0   False   14.98667   14.98333   14.81667   15   0.7933   0   27.155   27.155   83.3   0.011   3.392   3.392   3.392   3.392   3.392   3.392   3.392   3.392   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:12:50   0   0   6   24.67   24.44   18.1   9252   239   3.393   3.3971   0.8   0   False   14.97667   14.97333   15.01333   15   0.835   0   27.155   27.155   82.6   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:13:00   0   0   6   24.67   24.44   18   9252   249   3.393   3.3971   0.8   0   False   14.98167   14.98   15.05333   15   0.8767   0   27.155   27.155   83.3   0.023   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:13:10   0   0   6   24.67   24.45   18   9254   258   3.393   3.3971   0.8   0   False   14.99333   15.01167   15.02167   15   0.9141   0   27.155   27.155   84   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   292   0
24/02/2016 13:13:20   0   0   6   24.67   24.44   17.9   9254   268   3.393   3.3971   0.8   0   False   15.01   15.02   14.89833   15   0.9556   0   27.155   27.155   84   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   291   0
24/02/2016 13:13:30   0   0   6   24.66   24.44   18.2   9254   278   3.393   3.3971   0.8   0   False   15.025   15.02667   14.86   15   0.9972   0   27.155   27.156   84   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   291   0
24/02/2016 13:13:40   0   0   6   24.67   24.44   17.9   9256   288   3.393   3.3971   0.8   0   False   15.02833   15.03   15.14   15   1.039   0   27.155   27.156   83.3   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   291   0
24/02/2016 13:13:50   0   0   6   24.67   24.44   18.2   9256   297   3.393   3.3971   0.8   0   False   15.02833   15.02   15.09167   15   1.0767   0   27.155   27.156   84   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   291   0
24/02/2016 13:14:00   0   0   6   24.67   24.44   18.2   9254   308   3.393   3.3971   0.8   0   False   15.01333   15.01   15.02833   15   1.1226   0   27.155   27.156   84   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   290   0
24/02/2016 13:14:10   0   0   6   24.67   24.44   17.9   9254   318   3.393   3.3971   0.9   0   False   15.00167   15   14.87167   15   1.1643   0   27.155   27.156   83.3   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.9   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   289   0
24/02/2016 13:14:20   0   0   6   24.67   24.44   18.2   9254   328   3.393   3.3971   0.9   0   False   14.99333   14.99667   14.90333   15   1.2061   0   27.155   27.156   83.3   0.011   3.393   3.393   3.393   3.393   3.393   3.393   3.393   3.393   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:14:30   0   0   6   24.66   24.44   18.2   9256   338   3.394   3.3971   0.8   0   False   14.98833   14.99167   15.07667   15   1.2478   0   27.167   27.158   83.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:14:40   0   0   6   24.67   24.44   18.2   9254   348   3.394   3.3971   0.9   0   False   14.99167   14.98667   14.845   15   1.2895   0   27.155   27.161   83.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:14:50   0   0   6   24.67   24.44   18.1   9254   358   3.394   3.3972   0.8   0   False   14.975   14.97667   15.07667   15   1.3313   0   27.155   27.164   83.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:00   0   0   6   24.67   24.44   18   9256   367   3.394   3.3972   0.8   0   False   14.97   14.97   14.94833   15   1.3689   0   27.155   27.167   84   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:10   0   0   6   24.67   24.44   17.9   9256   377   3.394   3.3974   0.8   0   False   14.975   14.97167   15.00667   15   1.4106   0   27.155   27.167   83.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:20   0   0   6   24.67   24.44   18.3   9258   387   3.394   3.3974   0.8   0   False   14.975   14.99333   14.995   15   1.4524   0   27.167   27.167   83.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:30   0   0   6   24.67   24.44   18.3   9258   397   3.394   3.398   0.8   0   False   14.99167   15.00667   15.23667   15   1.4941   0   27.167   27.167   83.3   0.023   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:40   0   0   6   24.67   24.45   17.8   9256   407   3.394   3.3983   0.8   0   False   14.99667   14.995   14.86667   15   1.5358   0   27.167   27.167   84.6   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:15:50   0   0   6   24.67   24.44   18   9258   417   3.394   3.3983   0.8   0   False   14.99667   14.995   14.93833   15   1.5775   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:16:00   0   0   6   24.66   24.44   18.2   9260   427   3.394   3.3983   0.8   0   False   15.00333   15.01167   15.11   15   1.6192   0   27.155   27.167   84.6   0.023   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   289   0
24/02/2016 13:16:10   0   0   6   24.67   24.44   18   9260   437   3.394   3.3983   0.8   0   False   15.02   15.025   15.20333   15   1.6608   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:16:20   0   0   6   24.67   24.44   18   9258   447   3.394   3.3983   0.9   0   False   15.02   15.01667   14.98   15   1.7024   0   27.167   27.167   84.6   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:16:30   0   0   6   24.67   24.44   18   9260   457   3.394   3.3983   0.9   0   False   15.01333   15.015   15.17833   15   1.7441   0   27.155   27.167   85.3   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:16:40   0   0   6   24.66   24.44   18   9258   467   3.394   3.3983   0.9   0   False   15.01333   15.01   14.93167   15   1.7857   0   27.167   27.167   84.6   0.023   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:16:50   0   0   6   24.67   24.44   18   9256   477   3.394   3.3983   0.9   0   False   15.02   15.02   14.96833   15   1.8272   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:00   0   0   6   24.67   24.44   17.9   9258   487   3.394   3.3983   0.9   0   False   15.01833   15.01833   14.98   15   1.8689   0   27.155   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:10   0   0   6   24.66   24.44   18   9258   496   3.394   3.3983   0.9   0   False   15.03   15.03   14.99833   15   1.9104   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:20   0   0   6   24.67   24.44   18   9256   506   3.394   3.3983   0.9   0   False   15.02   15.005   14.99833   15   1.9478   0   27.167   27.167   84.6   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:30   0   0   6   24.66   24.44   18.2   9260   516   3.394   3.3983   0.9   0   False   15.01333   15.015   15.13667   15   1.9895   0   27.167   27.167   84.6   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.9   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:40   0   0   6   24.67   24.44   18.2   9258   526   3.394   3.3983   0.9   0   False   15.025   15.02667   14.94667   15   2.0311   0   27.167   27.167   85.3   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:17:50   0   0   6   24.67   24.44   18.2   9258   536   3.394   3.3983   0.9   0   False   15.01833   15.01667   14.91333   15   2.0729   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:00   0   0   6   24.67   24.44   18   9260   546   3.394   3.3983   0.9   0   False   15.02   15.01833   15.19333   15   2.1145   0   27.167   27.167   84.6   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:10   0   0   6   24.66   24.44   18.2   9258   556   3.394   3.3983   0.9   0   False   15.02667   15.02667   15.125   15   2.1561   0   27.155   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:20   0   0   6   24.67   24.44   18.2   9260   566   3.394   3.3983   0.9   0   False   15.02   15.01833   15.16167   15   2.1978   0   27.167   27.167   85.3   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:30   0   0   6   24.66   24.44   18.1   9258   576   3.394   3.3983   0.9   0   False   15.02833   15.03   14.785   15   2.2395   0   27.167   27.167   84.6   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:40   0   0   6   24.67   24.44   18   9260   586   3.394   3.3983   0.9   0   False   15.025   15.02167   15.10667   15   2.281   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:18:50   0   0   6   24.66   24.44   17.9   9260   596   3.394   3.3983   0.9   0   False   15.01667   15.01333   15.08167   15   2.3227   0   27.167   27.167   85.3   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:19:00   0   0   6   24.67   24.44   17.9   9260   606   3.394   3.3983   0.9   0   False   15.01333   15.00667   15.15167   15   2.3642   0   27.167   27.167   85.3   0   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
24/02/2016 13:19:10   0   0   6   24.66   24.44   18.2   9258   616   3.394   3.3983   0.9   0   False   14.99667   14.99667   15.16167   15   2.4059   0   27.167   27.167   84.6   0.011   3.394   3.394   3.394   3.394   3.394   3.394   3.394   3.394   0   0   0   0   0   0   0   0   0.8   0.8   0.8   0.8   0.8   0.8   0.9   1.1   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   0   72   288   0
Postby Burgerman » 24 Feb 2016, 19:17
You will see data only for 1 cell however so no cell balance data and only 1/8th as much...
Postby expresso » 24 Feb 2016, 19:22
Ok - is that it - ?
how do i export it to Excel spreedsheet - - i seen that text file - but seems like a bunch of stuff - cant make it out whats what -
Users browsing this forum: emilevirus, jefferso, martin007 and 502 guests
