Scollard wrote:We will check it with the balance battery tester you have once you make the battery side of the cable. You can plug the 2 cables together and then plug the battery tester into the balance connector. Then you just put a battery between 2 adjacent wires and see what the tester says. A battery between 0 and 1 should show as the 1st cell. Then you bridge 1 and 2 and it should show cell 2. You just keep going until you've tested each pair.
Burgerman wrote:Use contact adhesive inside the heat shrink before you shrink it that goes over the nylon mesh or it will pull out. I actually used adhesive lined heat shrink. Same thing. And used self amalgamating tape in places too.
Scollard wrote:I used adhesive lined 3:1 heat shrink at then ends of the mesh sleeve. You probably shouldn't use that for the wires inside the d-sub. If you notice, when you shrink it the rubber actually get thicker. You need to use just regular 2:1 heat shrink on the inside pins.
Scollard wrote:Either pin is fine, just so long as you do the same pin in both connectors.
Scollard wrote:You just have to move the red wire. Just cut off the heat shrink and desolder the red wire. You just have to heat it up until the solder melts and then pull the wire out. Tin the other cup and resolder.
Scollard wrote:I split my balance wires on the top and bottom. Five balance wires are not as wide as the 2 charge wires. By putting the charge wires in the middle you keep them at the widest part of the opening.
Users browsing this forum: FelipeOliveira and 171 guests
