S646se - Full LITHIUM Pack Project - First Attempt
Re: S646se - Full Pack Project - First Attempt
Postby expresso » 02 Apr 2016, 03:02
i turned everything off and on again - it no longer shows - NODE Charging only - but that didnt do the trick - same thing - Cells Exceeded - push to reset -
i went to the supply tab to check things there DC power supply enabled - its on Xh/ EH wiring mode - shows the banana message to use - yes and charge only
i hit it - and nothing - Cells exceeded -
Postby Burgerman » 02 Apr 2016, 03:09
Start from the beginning.
1. What is connected. Lithium, or Lead? Or Both?
2. Is balance wire connected?
3. What preset? Rename it .zip and post it here!
OK If charging lead only Either wiring mode OK. NO balance lead connected...
If charging Lithium only, You can charge FMA with main wires or without.
If charging both, together you MUST charge only the lithium, and connect balance wires AND and then have the lead connected to it as well. As if you are driving it, In other words you cant charge the lithium via the balance wires and the lead via the main banana connectors... You must have lithium and lead connected up.
Postby expresso » 02 Apr 2016, 03:18
this is only LEAD now - i am using the Anderson from the Chair to the Bananas to the PL 8 -
Postby expresso » 02 Apr 2016, 03:20
see if you can open this
Postby expresso » 02 Apr 2016, 03:21
trying to charge just the Chair Lead MK Gel 73ah - 24V -
Postby Burgerman » 02 Apr 2016, 03:25
THAT says:
Lead MK 73Ah + ADDON
So that wont work will it!
Its looking for the addon and the balance connector, and wants to charge a lithium!!!
You must slow down and read and absorb and be careful.
Postby expresso » 02 Apr 2016, 03:27
on the preset - it shows 6 Cells - - its for 12V though - this preset comes with the Pl 8
your preset shows AUTO for Cells count - i have nothing attached to the chair - NO ADD ON is connected - i am trying to charge from the Charge cable i always used before
which is the one i connect the ADD ON to also -
Postby expresso » 02 Apr 2016, 03:29
Burgerman wrote:THAT says:
hold on - its wrong the name but its correct - let me resend you again -
Postby expresso » 02 Apr 2016, 03:30
ok this is the one
Postby expresso » 02 Apr 2016, 03:35
i checked with volt meter - on the banana ends - connected to the chair anderson - shows 26.1V - so thats working -
if not the preset - what else can it be ?
Postby Burgerman » 02 Apr 2016, 03:41
That all looks good. Try changing cell detection from AUTO to 12 Cells. But it shouldnt make a difference.
So either you have something plugged into the PL8 balance connector, or you have the battery not connected for some reason. How is it connected? Did you test the connection? Make sure you have the right connectors plugged inro the charger, and the chair!
Postby expresso » 02 Apr 2016, 03:43
Hold on let me try that - there is nothing in the balance connector on the PL 8 - the chair end i just check the bananas - it shows 26.1V -
let me try goin to 12 Cells
it dosnt say NODE Charging ONly on the screen now - which it did before -
Postby Burgerman » 02 Apr 2016, 03:44
26.1V? Its very fully charged. That means it doesent need charging and the charger may think its too many cells. Drive the chair about 100 meters... Its because its over 13v per battery.
Then it will be ok and charge but it doesent need charging.
Best bet, connect the Addon, and use the Lead+Addon preset.
Postby expresso » 02 Apr 2016, 03:48
Ok that was it - needed to be set to 12 cell count - it was on Auto - i though Auto checks it and figures it out -
its ok - now i know - its already on the CV stage - there were charged last week and chair not used - when this is done - i will put everything back - ADD ON - connect to the Chair and - then will charge with my new cables all together -
ADD ON and LEAD as on - using your new preset you made me - should i check that setting for the Cell count - ? what should be there ?
Postby Burgerman » 02 Apr 2016, 03:53
Your lithium is 8S...
Its set to AUTO correctly. It uses the balance cable to tell it how many.
Setting LEAD preset to 12 Cells means it will not charge a 12v battery. Only 24V. But AUTO is also good. Because your battery will not be over 13 (26) volts when you want to charge.
Postby expresso » 02 Apr 2016, 03:54
the preset you made for charging both Lead and ADD on - is set to Auto Detect also - if i run into the same problem as this - what cell count should i put it to ?
just in case - i wont know till i actually go to charge - but not till i use the chair first again - wont be till monday - since the weekend is rain - unless that changes i use it tomorrow and charge again to see if everything is working there and if my cables are working also
Postby Burgerman » 02 Apr 2016, 03:54
Stop the lead charge. Its already charged.
Its safe now to fit the ADDON.
And charge now with the LEAD+ADDON preset. To see what it does. It wont give that error.
Postby expresso » 02 Apr 2016, 03:58
Burgerman wrote:ADD ON and LEAD as on - using your new preset you made me - should i check that setting for the Cell count - ? what should be there ? Your lithium is 8S...
Ok i see - if i want to charge a 12V - i have to set it to 6 cells or auto - Auto didnt work ? was it because it was already charged enough ?
when this is done - i will put everything back the way i had it - and next charge will be with your preset for both lead and lithium - with the new cables i made -
Postby Burgerman » 02 Apr 2016, 04:00
Go back 8 posts and read what I keep writing... SLOWLY!
Postby expresso » 02 Apr 2016, 04:01
Burgerman wrote:Stop the lead charge. Its already charged.
Ok will do that now - give me a short timei to get it all in place - maybe 10 mins -
Postby expresso » 02 Apr 2016, 04:30
Ok all done - its on the chair - connected and charging - this one worked fine -
but i have to say - this one cable solution - is great in one way but - those connectors are so hard to connect and disconnect - i worry about how long this will last here
i cant do them - my carer - PCA i call them - very hard to connect and harder to disconnect - so this worries me - i hope they get better
its so much easier to connect - disconnect the Anderson over these new connectors - i hope over time it gets better - but working :mrgreen:
i am using your combined new preset you made for me -
Postby Burgerman » 02 Apr 2016, 04:55
Well lets see what it does. Its charging lead, and balancing lithium... Should be interesting. Hows it look? Both are actually almost charged.
Postby expresso » 02 Apr 2016, 05:12
Looking fine to me - not much to put back but its still going and dropping - will leave for awhile longer - before going to bed - will stop it and leave it till i use the charge -
will post those graphs tomorrow when done -
thanks again - glad i got this done now and can start charging the 15 ah cells tomorrow - should take a week i think at my rate - i have 60 cells to charge -
Postby expresso » 02 Apr 2016, 05:29
Ok i see what you mean - if i ever went to recharge it again with LEAD along it wont be 26V so AUTO would work fine in then - i keep missing the posts - must be because when i post and you post - and i miss yours -
All good now -
Postby expresso » 02 Apr 2016, 05:33
its still dropping - - do you think its ok to stop the charge and just shut it down this time - or else i have to leave this going overnight - is it worth it now since i charged them both alone each fully -
or should i leave it overnight ? its at 690mA left - its been going a hour now - CV is 8 hours cut off i think -
Postby expresso » 02 Apr 2016, 05:46
i guess i just leave it overnight - still going - still dropping - i check it in the morning -
thanks BM -
Postby Burgerman » 02 Apr 2016, 09:49
Send me that saved data or post the pics here.
Postby LROBBINS » 02 Apr 2016, 11:22
I don't have Windows 8, but here's how to set what's shown in Windows Explorer in Windows 7 - I assume it's at least similar in Win8/8.1.
(1) Open WindowsExplorer. There may, or may not be, a menu at the top that says: "File Edit View Tools Help". If it's not visible, hold down the alt key and it should appear.
(2) Open the "Tools" item and there'll be a roll-down where the last item says "Folder options". Click that and you'll get a window like this:
(3) Click on the View tab and you'll see a long list of options:
Many of the "Hide" options are set by default. For the moment, the one you want to UNcheck is "Hide extensions for known file types".
(4) At the top of that pane there's a button that says "Apply to folders". If you click that, the next time you open Windows Explorer the view rules you've chosen will be applied to this folder and all sub-folders. If you do this in the root directory of the drive, it will be applied to the whole computer. (BTW, if you start this with the "View" choice instead of "Tools", you can set how your directories and files are display - icons, list, details etc. and that can also be applied to multiple folders. I suggest "details" unless you have a particularly small screen.)
CIao, Lenny
P.S. If Win8 is significantly different, I hope someone will chime in with whatever additional information Expresso needs.
Postby Burgerman » 02 Apr 2016, 12:59
It was different alright! It lasted 7 days here...
Windows 8 was really for touch screens. Only 7 and 10 are properly suited to a Desktop or laptop PC.
So get 10, its free...
Postby expresso » 02 Apr 2016, 16:36
thanks LRobbins - will have to give that a try later on - my parents visited yesterday and they bring me a load of mail they dont understand :) so i have to go thru it - mostly insurance EOB stuff - some bills etc, - they dont speak english so its my job -
Users browsing this forum: No registered users and 452 guests
