Burgerman wrote:It has a way of telling you if you are wrong.
the front screws would have the 7th roll of cells
expresso wrote:yes will the the 7th row tomorrow and send pic with buss bars connected to it -
i think i follow you - but i will take pics of the places where i will connect them anyway to be sure
i will connect them and not locktite them on the top when i get there - post the pics first before i lock it down
i would not want more than 3 things on any one screw - i may have to put the balance wire on the 3rd screw down roll 0 and 8 - the 2nd screw has two buss already and can add just the charge leads there - - making it 3 things -
the front screws would have the 7th roll of cells - which gives me 3 items on the screws also for the ends 0 and 8
will take pics first also -
Burgerman wrote:All looking good. Be sure to test by charging fully. Allowing to balance on the initial charge. Then taking at least 10Ah out with the charger. And recharge. And lok at the curves BEFORE you fit it. It will show up any problems like a bad connetion or loose bolt etc.
Burgerman wrote:105Ah of lithium will take you as far as 150Ah of lead. Plus you will save 60lb so add another 10 ot 12 percent. Same as 4 and a bit MK gels.
Add that addon, and you have the equivelent of 210Ah of lead. Or almost 6x MK gels! With the same weight as 1.3 of them.
Users browsing this forum: No registered users and 154 guests
