Scollard wrote:Looking good Expresso. Watch your numbers and make sure you hook it all up correctly.
I think BM finally sees how it's all going to fit together.
Do I get any props for thinking outside of the box? Literally!
Burgerman wrote:Now I see what you are doing. That seperate top layer only needed two thick wires. one at each end and just some thin balance wires really. But the thick cables wont hurt. Just bulky.
Burgerman wrote:They are all connected together. Doesent matter where the connection is to. In an ideal world it would be to the centre. But for what we are doing it not important. Just not the seperate top cells.
Burgerman wrote:should be ok.
If i did want to solder the 14 awg wire - what ring lug size would i need - i cant seem to find any smaller than the 8 awg size i have - i like to find something like this - but good for a 16awg wire
Burgerman wrote:Crimps on your balance cables are also a bad idea. Sooner or later you will live to regret it.
A properly crimped cable is a very careful engineering job with BETTER terminals with much more metal, carefully sized for the cables, with a crimper that costs 100 times more. Even then, they pull out in all but small sizes. Did you read the post I added on crimping?
Users browsing this forum: jefferso and 302 guests
