Burgerman wrote:http://www.wheelchairdriver.com/board/download/file.php?id=4850&mode=view these are fine, as long as they are soldered.
download/file.php?id=4851&mode=view Only 0 and 8 here need connecting with the heavy cable. All the rest, 1,2,3,4,5,6,7 can be connected with thin balance wire if you want. SOLDERED!
LROBBINS wrote:Here's a link to one of many sites with tables comparing AWG and metric wire sizes: http://www.technick.net/public/code/cp_dpage.php?aiocp_dp=guide_awg_to_metric AWG8 is 8.36 mm2, hence even larger than the 6 mm2 wire John says is adequate for your heavy power leads.
Burgerman wrote:You manage to make every post almost impossible to understand.
I dont know what size your cables are without looking up stuff...
Last attempt! You need thick wires to the ENDS of your extra bit that sits on top. 6 sq mm is fine. All the other connections can be small wires.
You NEED to solder the balance wires. Because sooner or later it will fall apart of go high resistance or something and you will think its a bad cell, balance issue or something.
Crimps alone, are great for DIY teenagers fitting spotlamps to their cars... OR done proffesionally with absolute precision and manufacturer supplied equipment on a production line.
Because a typical DIY crimp with a thin soft terminal is useless. No matter how its done. And glue / heat shrink wont make a bit of difference to future oxydation.
Burgerman wrote:14 gauge is 2mm sq?
So thats thick enough for balance connections. To connect 1, 2, 3, 4, 5, 6, 7, but 0 and 8 MUST be the same cable shown in your other photos (ideally). The thicker ones are where all of the Amps will flow if you take say 150A from the battery. At least about 20% of it. Slightly thinner could work, but for the sake of consistency I wouldnt...
But there are so many connections that DIY crimping is not a good plan. Adding a little solder only takes a second to each connector.
viewtopic.php?f=2&t=5702&start=400 have a read of the posts i added here to try and convince you!
Burgerman wrote:Yep!
Never mind, you can have all the fun of trying to figure out whats wrong in 18 months time! When one oxydises or falls out...
Burgerman wrote:Not if its ok. But these things like oxidised wires that go black for eg takes time. Adding a little solder means that they stay connected and dont cause problems later. At least its only the 9 charge balance wires? And they dont get wet.
But the smaller the wire the better for crimps. Larger wires need specialised equipment and stronger harder terminals with thicker walls to securely crimp. Those can be crimped wuth a hydraulic crimper so that it really is as secure as soldering. And oxygen is excluded. But the cheap copper tinned/zinc plated ones are far too weak. These are cast rather than a bit of thin copper tubing.
Burgerman wrote:I never know exactly what wires you mean. But I was talking about the extra cells sat on top.
Burgerman wrote:Forget about those. The CELLS ON TOP need a fatter cable for the pos and neg. As I have explained above several times!
Burgerman wrote:But I already looked back just now at your pics and those already exist!
download/file.php?id=4839&mode=view
Length of connection is also meaningful . A 3 inches long 1.5 mm wire can take 30A easily.
Your add-on will only be drawn 10 or 15 amp at peaks for very short periods of time, so 1.5 mm for the two ends is already overkilled. Thinner wires even, for the balance leads.
Meaningless to chase after big cables blindly.
For a second or two after which the insulation melts off it. I charge 30A on 10 mm sq cabes and they get pretty warm. And thats 7x bigger...A 3 inches long 1.5 mm wire can take 30A easily.
- i can drop a solder on the end after i crimp it on uninsulated rings -
and i am going to use 8 AWG wire for 0 and 8
Burgerman wrote:and i am going to use 8 AWG wire for 0 and 8
10 will do. Silicone like the PL8 charge cables, is used because its very flexible, and because it doesent melt when it gets quite hot charging at 40A... So that type of cable may make it easier.
12 or 14 will do for balance wires. But 12 physically more robust.
Ok - when you say balance wires - you mean 2 4 6 Cells ?
i didnt know they are considered the balance cells - i think i get that now - i didnt know - the two ends are the main power and get charged up and used heavy - all the numbers are considered the balance wires - Cells etc,
2 4 6 , 1 3 5 7 - all balance
Users browsing this forum: acid_coke, duke1, jefferso, LROBBINS and 423 guests
