its headshrinked glued etc,
so if those were correctly done - with clean wire to start - they wont go bad - i would think
the XT connectors are a pain - small area to work on and surprised how they handle 90A constant - but such small wire - i mean really 12 AWG is the best fit -
Scollard wrote:Looking good. That's exactly what I had in mind when I thought it up.
You have gone from Group 24 capacity to Group 27 capacity.
And if you slap on the 36Ah add-on you will have EPIC RANGE.
this weekend if warm enough - i will be testing the ADD ON chair - shooting for a 20 mile run and see how much i used up there in battery when i recharge -
steves1977uk wrote:Is there a low voltage cutoff setting on the Pilot+? There is one on the R-Net system, but never seen it in the Mobility OEM PC Programmer.
LROBBINS wrote:Even if your Andersons won't mate, you can pop the pins out of one and put them in the other color shell - the pins are all the same. Just need a small screwdriver to push down the leaf spring to get the pins out.
Burgerman wrote:Dont go too mad, your MKs are new... They need a few cycles before you fully discharge them for long term benefits.
Users browsing this forum: No registered users and 276 guests
