http://www.wheelchairjunkie.com/forums/ubbthreads.php?ubb=showflat&Number=72226 Regarding battery gauges, we remain dedicated to providing the most accurate possible in relation to battery state.
Our current battery icon isn't the most descriptive, but it does drop in 1% increments. By contrast, the current PG R-Net drops in 10% increments, meaning it shows a totally full charge till you're 10% down, then it doesn't drop again till 20% down, and so on. This does give the perception of security, but not true accuracy in real time.
By contrast, we run in 1% increments and are moving from our current icon back to our industry-first numerical gauge.
When you drive from your bedroom to your kitchen in the morning, will you see it drop promptly from 100% to 99%? Absolutely -- that's how battery voltage works. However, over the entire range, you'll know a far more precise gauge of charge. (Remember, though, that based on ever-changing battery chemistry, no gauge is absolutely accurate in real time.)
So, yest we are coming out with a new numerical gauge version. Thank you.
c500user wrote:Succes!
After downloading the mcp.zip file mentioned by woodygb, I unpacked and installed it as directed in the programming thread.
I was able to connect without any trouble. I downloaded all the parameters from my C2000 to my laptop and disconnected again. Next step is trying to figure out what all the different parameters do. There are some that I may want to change but also a lot that I absolutely should leave alone! The learning/sorting out will take a while because I would like to end up with a "working" wheelchair, rather than an "interesting project"![]()
Thanks everyone for sharing your information!
Links to files and instructions:
USB-CAN adapter
Bought from ebay for € 20, shop name kiss_buymsiss
http://www.ebay.nl/itm/USB-CAN-USB-to-C ... Sw1ZBUw65~
http://www.ebay.co.uk/itm/USB-CAN-USB-t ... Sw1ZBUw7EJ
mcp.zip
viewtopic.php?f=2&t=2757#p36057
LXN4py2s.dll and QM_USB.rar
viewtopic.php?f=2&t=2757#p36028
LMDZ version of QM_USB.dll
viewtopic.php?f=2&t=2757&p=73376&hilit=lm_usb#p73389
Curtis 3.12 sw
viewtopic.php?f=2&t=2757&hilit=curtis+3.12&start=280#p55632
woodygb wrote:
Pick MC-2 Slave from the options.
rover220 wrote:Had a new I level in this week with q logic. The Curtis handheld I have for otto bock chairs will not work on q logic. Will try 1314 pc based programmer next week hopefully.
woodygb wrote:rover220 wrote:Had a new I level in this week with q logic. The Curtis handheld I have for otto bock chairs will not work on q logic. Will try 1314 pc based programmer next week hopefully.
I assume that the Ottobock handheld was suitable for the EnAble50 ?.,,,, NOTE:-The EnAble40 has the same 5 pin plug but uses a serial protocol rather than CAN.
Users browsing this forum: rover220 and 514 guests
