http://www.wheelchairdriver.com/board/download/file.php?id=5569&mode=view
Set 60A
expresso wrote:LROBBINS wrote:Expresso,
instead of plugging and unplugging, you can wire in a switch to do the same thing.
which means what excatly - i have a cell monitor that i got from Shirley - but never did anything with it - if theres a way i can wire it and leave it alone - not draining my battery in the OFF postion - then when i want to see it - turn it ON - check and turn it Off again -
that i can look into - i would do it during the winter when i take it out to replace the main power wires - i need more details about this -
Burgerman wrote:http://www.wheelchairdriver.com/board/download/file.php?id=5569&mode=view
Set 60A
steves1977uk wrote:expresso wrote:LROBBINS wrote:Expresso,
http://www.ebay.co.uk/itm/Heavy-Duty-To ... SwqYBWn9F4 or http://www.ebay.co.uk/itm/5pcs-AC-250V- ... rkt%3D1%26 Use one of these types of switches to isolate both the negative and positive wires on the cell monitor, although you might get away with just isolating the positive wire.
thanks - i really dont know whats the best way for me in my case - i have to figure this out better - i have a cell monitor i got from Shirley - if i can use that somehow - i wonder if i run long balancing wires from the box up to my seat and then can connect it from with in my chair seating myself and disconnect it - i would have to keep this long balance wires cable on my seat side - thats all i can think of right now -
shirley_hkg wrote:WOW . That's way too big to my 1cm micro switch .
shirley_hkg wrote::lol: You don't need to remove battery from chair for rewiring .![]()
Solder a DB male connector to the monitor . That's it .![]()
Burgerman wrote:If it takes a small 50mA (SHIRLEYS FIGURE) from one cell group. it will take 1Ah hour meaning 1 hour to rebalance the battery, at the end of charge when recharging in a 20 hour day of typical use. Because the PL8 has 1A true proportional balance capability, it will rebalance safely and smoothly but add 1 hour.
Or will take an additional 10 to 20 hours on charge, repeatedly bouncing the cells up to a silly voltage if you were still using the on/ off BMS with its inadequate 50mA to 100mA balancer! Boing boing boingIn reality the charger will probably turn off before they get balanced. So gets worse next time! And over and over.
Burgerman wrote:Not enough to detect... A tiny momentary switch in the one negative wire. Next to the monitor. You have to keep it pressed. Use a LATCHED switch to keep it on or off if you prefer.
https://www.amazon.com/6x6x6mm-Momentar ... +momentary 1/4 inch square.
Bigger... if you want. https://www.amazon.com/Pieces-12mmx12mm ... icroswitch
Cut 1 wire, add in line with your iron. And 2 tiny bits of heat shrink.
A latched one but a bit big? Up to you! I would use this. http://www.ebay.co.uk/itm/10-x-DIP-PCB- ... 1060706375
A tiny switch http://www.ebay.co.uk/itm/CHROME-PLATED ... Sw-YVXlgMX
LROBBINS wrote:Yes, their are four mounting legs/contacts on these switches, but they are actually 2 pairs - two are connected internally to one switch contact, and the other two to the other switch contact. Double check with your ohmmeter to make sure you get them wired correctly, or you will simply have a permanent connection rather than a switched one. These are designed for printed-circuit board mounting and the four legs ensure a solid mount to the board when soldered. You can actually use ANY SPST momentary or latching switch that you like - all you are doing is opening the minus lead to the monitor, and connecting the two ends of the opened wire back together with the switch. Switch open - no current drain, switch closed - monitor active.
Burgerman wrote:So 44 miles on 102Ah? Actually about 4 or 5 less because recharging is about 95 percent efficient. You really used 97Ah(ish).
So you had about 40% left. Or 25 percent if you leave a safe bit in reserve.
So you could have gone 44miles + 25% safely or another 11 miles, giving a safe 55 miles possible. You need to get up even earlier.
shirley_hkg wrote::lol: AVE SPEED of 10kph as expected .
so if i had my PSU and charger i could have charged easy there - with out the PSU - i would need to charge from a Car Battery only ?
Burgerman wrote:so if i had my PSU and charger i could have charged easy there - with out the PSU - i would need to charge from a Car Battery only ?
Unless you can do magic!
If you had my BM3, same range, but 16mph, you could enter the New York marathon, and win it! Just follow the leader to the last 100 meters, then pull out and pass him, waving arms!
Burgerman wrote:If you put that 140Ah lithium on a brushless invacare chair it will go 75 to 85 miles!
Burgerman wrote:Without knowing how many Ah per mile its hard to guess. But maybe. Just.
Users browsing this forum: No registered users and 111 guests
