frogsuk wrote:4. Invacare Storm 3 that is in snail mode again with an ACS controlerjoystick that I want to tweak so I can go up the woods in the village at the same 4mph as the Wheeltech instead of about 2mph.
I'm more than capable of making the cable for the R-Net but am having a real problem trying to get the R-Net software. I have a XP Panasonic Toughbook that I use for other vehicle related and programming software butI am getting pretty desperate now as I really need to alter the parameters of the Sectra as the only other chair I can drive from -"(- headrest) is the Wheeltech that is currently as mentioned above, dead
Please help![]()
PS based is south west Wales, someone's got to be!
rover220 wrote:frogsuk wrote:4. Invacare Storm 3 that is in snail mode again with an ACS controlerjoystick that I want to tweak so I can go up the woods in the village at the same 4mph as the Wheeltech instead of about 2mph.
Please help![]()
likely the magnet switch that controls the slow speed switch has moved causing that problem. join the 2 purple wires coming from the CLAM to permanently disable this issue.
woodygb wrote:Pic that may help if you take the pod apart ...it shows the location of a black locking oval pin that should be depressed to allow the board to slide out to gain access to the various activation pads on the reverse side.
memturbo wrote:yes read the articles tried to sign up 2 months ago thru that site did not approve my request can't download anything,
Would someone be willing to share their username/password ?
Found nothing about straight to serial connector just usb .
Squanto wrote:I have been a Lurker on here for a year or so, and finally bit the bullet and signed up!
I am building a modified chair like the BM3 but as Quicie F55 are like Rockin Horse Teeth, I have gone for a Kymco K-Active as my Base model - cheap too when new and still being made, chassis is almost identical to F55
Now I have several chairs all running on Penny & Giles controllers mostly VSI & VR2 which I would like to program.
Where can I get the Programming software preferably OEM version ???
I have got many FTDI & Chinese Serial to USB leads (from Arduino and model helicopter Gyros)
Many Thanks
Mark Squance![]()
Plymouth, England.
Smitty62 wrote:Hello
can anyone point me to programing software for a jazzy 1100, Pilot Controller D49637
thank you
lakonas wrote:Hi guys,
I'm looking for the mobility scooter programming software for the Solo controller.
Thanks in advance!
Users browsing this forum: emilevirus and 510 guests
