expresso wrote:GF and Wifehopefully not both at the same time - Go Shirley
Burgerman wrote:Your Hyperion is faulty. Probably. USB, also a known problem. And why I converted mine to Bluetooth. 4 out of 8 of mine failed over the years. You need to move on. PL8 is far more reliably built. Electrically stronger. 3 times the power, 4x more balance power. And is still manufactured.
Burgerman wrote:Do yourself a favour, get a PL8! Things move on fast in the hobby world. Its better suited to what you are doing.
Burgerman wrote:Yep.
I understand 3.6 is the normal voltage for lithium operation. What is the ideal per cell charging voltage that would tend to be safe, insofar as not likely to burn the cells up when topping off?
scooter wrote:The inability to charge anywhere is something that is holding us back from leaving lead.
You know, the more I think about it, the PL8 seems like a pretty good deal indeed. I'm not quite ready(yet) to make the jump to lithium. Need to learn more first.Burgerman wrote:
PL8is actually cheap. If reliability worries you get 2. Compare its capability, and power, to any dumb 40A lead brick charger from china!
shirley_hkg wrote:Line them up to a 14P8S rated 24V 210AH for testing.
Found only one bad among 112 cells, and get replaced.
After balancing, 200 AH were released on the first discharge, which was stopped at cell voltage @3.0X volt. Don't want to go too low.
Cells are good and capacity seems up to standard.
Together with Nandol's 190 ah pack , that is over 400ah here , and it is a BOMB.
expresso wrote:the chances are you never need to charge outside ever - unless you ride over 50 miles on one ride before charging-
expresso wrote:
PL8 connected to PSU .....
shirley_hkg wrote:shirley_hkg wrote:Line them up to a 14P8S rated 24V 210AH for testing.
Satisfied with the quality of these cells , and some members want to acquire some too ..
Here is the link : http://e22a.com/h.0nKb8D?cv=AALdshWq&sm=7ff3ed
However , it will be a task to ship them overseas .![]()
scooter wrote:expresso wrote:the chances are you never need to charge outside ever - unless you ride over 50 miles on one ride before charging-
The ability to remotely charge also includes trips many miles away from home, by either car, bus or train.
While you are right that we will be unlikely to hit this limit locally, I wonder how much "gear" will I need to take on a train trip to charge away from home. With lead, this is a 5 amp built in charger. With Lithium, it sounds like we will need 2 PL8's, 2 HEAVY power supplies in order to charge, unless a single power supply will work. My understanding is you go above 8S, you have to have 2 pl8's. I am thinking of group 24 replacements, 7P6S per pack X 2 for 43.2 volt, which if I am calculating correctly is 84ah @ 43.2v. What would be the smallest gear to charge out of town, where we do not have a car? Of course, I understand during car travel, use the car for this charging while riding between cities. I transport scooters in a small trailer.
Of course, maybe the old unit should be left lead, and used for train travel and backup, and forget the extra prep, or swap the pack for lead for such trips.
The engineer in me also wonders if a simple pull down circuit could be constructed and attached to the balance connector to keep each section from over volt during a conventional charge from a standard charger in these cases?
Irving wrote:Hi S_hkg
I read &re-read that page several times via google translate and still couldn't figure out what was being offered or how to order it.. Also those 40152 don't appear to be threaded so how do you connect them?
Users browsing this forum: acid_coke, Burgerman, Seafighter, sergey0, shirley_hkg and 617 guests
