Burgerman wrote:Yes a Nandol version of a 24v bm3 built by his blacksmith friend.
expresso wrote:has Shirley ever shipped the pack out to one of the other users here - he build a 190ah pack for someone and then cant find anyone to ship it to him - Nadol i believe
thats a problem
shirley_hkg wrote: All the carriers we have contacted asked for a safety certificate from the manufacturer , when we declared shipment of lithium battery .![]()
Surface parcel by post to Lisbon limits to 20kg , where as Nandol's two blocks weight 25kg each .![]()
I recently just noticed that the limit to UK is 30kg , so I will try to ask Nandol , when he gets well , if that's OK to enroute to UK / France .
Burgerman wrote:You will find a tiny black fuse in one of the battery cables under some heat shrink or pvc sheath.
This is what I find on almost every chair without a breaker. This is also what you should add, if you don't use a breaker. Look at your old battery cables carefully... Fit one between 100and 150A as here. This was a 100, I swapped it to 150 when I blew the 100. Its about 1 inch long, and 3/8th wide. Dont get a physically bigger one, which are very common. The one below is a stock thin loom.
Ebay, http://www.ebay.com/sch/i.html?_from=R4 ... 0&_sacat=0
Users browsing this forum: LROBBINS and 60 guests
